Home > For Sale > Turbo Mini - needs finishing - Scotland
hammoj28turbo
Member #: 1502
Aberdeenshire, scotland.
It was on road, however, engine and interior stripped out so now rolling shell.
All parts included apart from a clutch and the car could ideally do with a new front wiring loom. Engine needs to be assembled onto gearbox and fitted.
Shell:
Fully repaired with new inner wing, front end, sills (real ones). Shell is excellent and very solid. Repainted in Ford Panther Black metallic. Wood and picket arches.
Engine/Gearbox
Block and head rebuilt by Iain Hargreaves at Avonbar/AVR Racing. Advised it could potentially put out around 130bhp on mild boost.
Spec is as follows:
1293cc Turbo block,
Block acid dipped and new oil gallery plugs/core plugs
Omega pistons
H/Duty bearings
Fully reground, balanced crank,
new cam bearings
phase 2 cam,
high cap oil pump,
HD cam followers
Duplex chain
Rebuilt head, unleaded conversion,
New electronic Distributor,
Sytec fuel pump
Bleed valve
Modified plenum with Dump Valve
Silicone Hoses
Fiesta RS Turbo intercooler
Oil Cooler
Large bore downpipe
Play Mini rearcentre exit with stainless straight centre section.
Straight cut gearbox by Mini Speed with SC drops, centre oil pickup, KAD quickshift
Rebuilt turbo T3 turbo by Turbo technics
Chassis:
6x12" alloys
Gaz adj shocks
Hi-Los
-1.5 camber all round
Solid bushes on front subby, rest are poly
Adj tie rods
Interior:
3 clock dash
Silent coat soundproofing
Roll Centre 6 point cage
Cobra Cub Bucket seats
My build thread is here:
http://www.scottishmini.net/forum/showthre...hlight=hammoj28
I've probably forgotten a quite few things. i'v had the car for over 10 years and hoped to finish it, however I do not have the time due to other commitments and it seems a shame for the car to sit in storage any longer. It needs to be used and enjoyed!
If you require any more photos please contact me. I'll upload more recent ones soon.
Car is located in Banffshire near Keith Scotland.
Looking for £5000 to take the lot away, I don't really want to break it and I don't have the time to put it back together.
If interested please PM or contact me at hammy608afb@hotmail.co.uk
Edited by hammoj28turbo on 23rd Jan, 2016.
Shame, I always liked the look of this car. Good luck with the sale.
D4VE
Member #: 10749
lowestoft suffolk
Me too.. have you changed your name? Or am i thinkining of someone else.. Altho the pic at the bottom with the b'mers the same?
Nothing gets past Dave lol
hammoj28turbo
Member #: 1502
Thanks guys. Always had the same forum name. Funnily enough BMW is also for sale.....
