Page: |
Home > General Chat > evans waterless coolant | |||||||
239 Posts Member #: 7577 Senior Member belgium |
21st Jan, 2016 at 08:47:58pm
evening all,
21st Jan, 2016 at 08:57:40pm
Try the pink stuff rather than the blue.
21st Jan, 2016 at 09:42:26pm
Water wetter increases heat transfer because it lowers the surface tension. The waterless coolant decreases it because it's not as efficient as water.
21st Jan, 2016 at 11:37:36pm
The rusty coolant is an indicator that air is getting in. Air is likely getting in when the engine and rad cools and draws a vacuum. there is more to an engine coolant than just antifreeze. The inhibitors used in some coolants these days i think zre a bit like everythjng else, just not what they use to be, and never perform as well as they did, back then. If you buy cheep còolant, it likely wont last as long as we would hope.
Edited by Sprocket on 21st Jan, 2016. On 26th Oct, 2004 TurboDave16v said:
21st Jan, 2016 at 11:48:41pm
Awful stuff, honestly you'll regret putting it in. You have to flush the entire system with a cleaning agent before using it, and if you get a leak it leaves everything really oily, and it is a pain to clean it off.
![]() 67 Posts Member #: 8956 Advanced Member Algarve/Portugal |
22nd Jan, 2016 at 01:00:58am
I agree whit VW stuff, taken from my engine whit about 700km, absolutely no rust.
Edited by R.Rodrigues on 22nd Jan, 2016. |
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
22nd Jan, 2016 at 05:06:19am
What about the warning on using the pink stuff in old engines ? Is it just a load of rubbish or is it not a good idea ? |
22nd Jan, 2016 at 07:49:36am
On 22nd Jan, 2016 tadge44 said:
What about the warning on using the pink stuff in old engines ? Is it just a load of rubbish or is it not a good idea ? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
22nd Jan, 2016 at 09:06:59am
well, the engine is in a moke now, so i has an expansion tank fitted already, but i noticed that the wrong rad cap was on the rad itself. replaced it with a correct one and have drianed the system already, bought some engine flush, will start up the engine now with the flush in and dimineralised water. drain that, flush again and then put normal coolant in and then see what it looks like after 500miles
Edited by pieter on 22nd Jan, 2016. |
22nd Jan, 2016 at 10:46:03am
On 22nd Jan, 2016 R.Rodrigues said:
I agree whit VW stuff, taken from my engine whit about 700km, absolutely no rust. ![]() Is that G12 or G12++ ?.... On 26th Oct, 2004 TurboDave16v said:
22nd Jan, 2016 at 02:25:03pm
I have been told that the pink stuff will attack copper and brass so bad for copper head gaskets or rediators.
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
22nd Jan, 2016 at 05:36:15pm
What about the warning on using the pink stuff in old engines ? Is it just a load of rubbish or is it not a good idea ? I hadn't read this before but, after a bit of research on the WEB (Google is your friend) it appears to have some validation from reasonably acceptable bodies (like from the FBHVC) say that the adittives in the "pink" stuff OAT (Orgainic acid) are bad on certain silicones (earlier gasket sealants) or lead (solder on earlier copper based radiators). The blue uses IAT (In-organic acid) which doesn't attack the silicone or lead but has a much shorter protection life. So, if you believe what they say, if any of your coolant parts are pre 90's and involve silicone or lead (solder) I guess I would avoid the pink stuff. Modern radiators are all aluminium tubes and pressed into plastic headers which is probably why the change in coolant was made. I've seen plenty of older Mini radiators where the pipe stubs are soldered into the headers (even if the tubes themselves are brazed). Thoughts ??? Schrödinger's cat - so which one am I ??? |
22nd Jan, 2016 at 07:45:07pm
The manufacturers of the coolants have made this an unnecessarily complicated subject for the enthusiast to make the right decision in choosing which coolant to use.
22nd Jan, 2016 at 08:05:27pm
You hit the nail on the head in your first sentence colin.
22nd Jan, 2016 at 08:35:29pm
Comma extreme g40 5 year fluid really good stuff I use it in everything I work on now as it's backward compatible aswell so won't affect anything if you top up with other coolants |
22nd Jan, 2016 at 09:02:37pm
On 22nd Jan, 2016 Sprocket said:
Is that G12 or G12++ ?.... I believe its the G12, its from febi bilstein 1,5L concentrated it have the red cap, the purple cap I believe its the G12 plus. https://public.dm2303.livefilestore.com/y2p...&rdrts=74211967 |
![]() 218 Posts Member #: 9213 Senior Member Scotland |
4th Apr, 2016 at 09:50:17pm
deary me. Just trawling through the search for coolant information and im now more confused than ever |
4th Apr, 2016 at 10:20:00pm
I am guessing this is the stuff?
Page: |
