Home > For Sale > Stuff For Sale (CLOSED)
Sell up of stuff which is mostly getting in the way these days, most of which was destined for my abandoned and sold Clubby project.
MPI Roof Aerial with base
https://www.flickr.com/photos/minimadmotorm...57663592648872/
£6 posted
Black DSN Billet Oil Filter Head (never used)
Has slightly poor anodizing but nothing that you would notice.
https://c2.staticflickr.com/2/1559/24142730...566dc2ecd_b.jpg
£45 posted
MED Verto Ultra-Light ST1 Clutch Kit
http://www.med-engineering.co.uk/products/...ultra-light-st1
About 1500 miles on it.
https://c2.staticflickr.com/2/1450/24309809...4643f4c75_b.jpg
https://c2.staticflickr.com/2/1483/24309808...ec870f2d1_b.jpg
£110 + postage SOLD
New leatherette handbrake and gearstick gaitor
£5 Sold
Seat Extension Brackets
Not perfect condition but plenty usable
£A coffee at Bingley Sold
Paul Wiginton Spark Plug Indexing Washers
£5 Sold to madmk1
Turbo Carb Abutment Plate
Modified to use a HS style throttle cable but can easily be reverted to use the standard HIF cable with careful use of the grinder
£5 Sold to Carlzilla
KAD Alloy Radius Arms
As above in great condition ready to fit, bought from Matt (alaskanow0) with a little under 1000 miles total use
£350 Sold to Carlzilla
Boot Liner Kit
Been sat in garage roof for a couple of years, don't know it's origin doesn't appear to ever have been used.
£10 Sold to Shauna
[u]AP Racing Bonded Clutch Plate[/u]
Approx 1500 miles use in my clubby, worked a treat still 7.3mm thick so minimal wear
£25 Sold to madmk1
Nippon Denso Alternator
I seem to recall this being a 60a item I got from eBay (apbellamy has the same one I think)
£60 Sold to ministar
Patented MRA A+ Dizzy Bung
£5 Sold to kezzboycat
Turbo Oil Drain Flange
I believe this is for GT17
£5 Sold to clubman91
Straight Cut Gearbox
Built approx 3000 miles ago with Clubman gear-set, central oil pickup, all new bearings, central oil pickup, x-pin diff, 3.1 final drive, fitted with turbo nose bearing and comes with matching transfer case with new Torrington idler bearing installed.
Was fitted to my turbo clubby and drove faultlessly.
£650 Sold on facebook
Mirage T2 Setup
Mirage Manifold, Elbow and Downpipe with lambda boss
Mirage Rebuilt R5 GT Turbo T2 with 360 degree bearing and re-profiled compressor housing
Braided Oil Feed
Actuator and Bracket
Oil Drain Setup (could probably do with a new bit of silicone hose)
Manifold Spacer Shim (without this the compressor housing fouled on my block but on my other engine I dry built it didn't)
Modified Turbo Inlet Manifold that has the flange slimmed down to match the Mirage manifold (not pictured)
I was running up to 14psi with this setup on my 1293 but this should be equally at home on a small bore engine too.
https://farm9.staticflickr.com/8689/1708951...d814facba_b.jpg
£500 Sold to Wil_h
Minisport 1.3 Roller Tip Rockers
Bought new from Minisport a few years ago, have done 1200 miles total on my turbo engine
£125 Sold to Wez89
Small Disklok
£20 Sold to Turbo_Jonesy
MED Forced Induction Special Cylinder Head
36 x 32mm offset valves
29.5cc combustion chambers
11 Stud
Double Valve Springs
High-Flow Silicon Bronze Valve Guides
Machined for dry deck port (home-made blank supplied)
3 bottles of Castrol Valvemaster Lead Replacement included in sale
Bought from Matt (alaskanow0) with a little under 1000 miles total use
£500 Provisionally sold on facebook
TIM Water Temp Gauge + Sender
MK1 MG Metro Steering Wheel
Could do with a little stitching repair
£10 Sold on facebook
New Mini Special Wheel Arches and Sill Strips
Few marks from storage but nothing that won't clean up
£10 Sold to clubman91
Edited by John on 14th Feb, 2016.
Messaged you on facebook about the radius arms, just noticed the abutment plate, ill have that too.
slater
Member #: 1291
Suffolk / Birmingham
Lots of bargins to be had lately!
That t2 settup is a bargain imo
Only t2 powerd mini ive been in and the boost is just always ready to play
All a bargain really, that head is a good grand new
Shauna
Member #: 10424
Swansea boyo!
I'll take the boot liner kit off you John, fed up of everything rattling around in there now!
John , Matt ? Can one of you confirm if that's my old med head !!
Thanks
ministar
Member #: 10760
Derby
I messaged on facebook and here regarding the alternator. Cheers
alaskanow0
Member #: 8466
Mansfield
Thanks
Yep that the one.
All PM's replied to.
kezzboycat
Member #: 10371
leicestershire
Pm u John
How big will the cc in the pistons need to be with the head for a suitable cr
On 21st Jan, 2016 kezzboycat said:
Pm u John
If you had zero deck height and 10cc cast Omega pistons on a 1293 your CR would be approx 8.4:1 which is about bang on really!
very tempted with the T2 gubbins. Hummmm.
You big tease! *happy*
Go on then, you twisted my arm. Can it wait till next month though? I'll bob down one evening.
Ok,
Oliver is planning a little visit early Feb and has agreed to deliver on the TM express if that suits you?
Edited by John on 21st Jan, 2016.
Callum
Member #: 10396
Stoke-on-Trent
Let me know if will_h changes his mind on the turbo, been going backwards and forwards all day on this one then just decided I would have it! You snooze you lose!
No problems.
Sounds like a plan.
PM me your bank details and I'll transfer the dosh.
Hahaha!
Will do!
baker_boy
Member #: 9226
Rushden
I'll take the gearbox if it doesn't sell on Facebook.
i got nothing but time..
Original post updated, baker_boy I'll let you know if he doesn't show up for the box tomorrow.
Wez89
Member #: 11072
Stoke-On-Trent
Pm'd about rockers
John. Can I buy everything you've got left for about half what you are asking including first class postage?
No, thought not. After all we are all living in the real world.. .
Hahahah! No! I will however chuck 3 bottles of Castrol Valve Master in with the head!
Rockers sold btw! I'll update the post later.
Users viewing this thread: none. (+ 2 Guests)   Next ->
