Page: |
Home > General Chat > Engine carnage | |||||||
95 Posts Member #: 10924 Advanced Member Wroclaw/Poland |
19th Jan, 2016 at 07:10:09pm
Ok so it's not that bad. Yet! But my guess is it would lead to spectacular failure. Think you guys might like to have a look and guess what happend here:
Edited by SadamPl on 19th Jan, 2016. Made in Poland build thread:
19th Jan, 2016 at 08:41:02pm
had worse lol
Edited by Brett on 19th Jan, 2016. Yes i moved to the darkside |
20th Jan, 2016 at 05:21:05pm
Oh dear you have been trying, was it a 100,000 engine you wound the boost up and that happend?
20th Jan, 2016 at 05:25:31pm
Looking at the way the primary has worn the crank i would say its got many launches under its belt !!
20th Jan, 2016 at 08:59:48pm
That's tame. Should of seen my tritec engine out my cooper s.
21st Jan, 2016 at 09:42:06am
its had a hard life by the looks
21st Jan, 2016 at 11:42:36am
Ok, so I didn't gave you all of the info yet. Made in Poland build thread:
![]() 696 Posts Member #: 10034 Post Whore Birmingham |
21st Jan, 2016 at 12:35:49pm
If there was no gasket, the 2 locating pins (should) still hold the transfer casing in alignment. Were they pressent and still a snug fit? If not, that could mean the lower two transfer gears were twisted out of alignment too. Missing the gaskets off is quite a bodge. Sadly, if the last builder didn't realise they could have made several mistakes along the way that led to this.
Edited by PhilR on 21st Jan, 2016. |
21st Jan, 2016 at 01:33:47pm
Both locating pins were present but they are both in gearbox casing. So no gasket still means engine and gearbox are too close, therefore primary gear/idler gear are too close.
![]() 2094 Posts Member #: 9894 Post Whore Dorking |
21st Jan, 2016 at 03:38:30pm
I thought it was quite common to not use the gearbox to block gasket. A bit of sealant was a better option than the gasket.
21st Jan, 2016 at 05:01:29pm
That makes sense. I was thinking the top dowel was in the block for some reason |
22nd Jan, 2016 at 05:20:39pm
I'm planning to test how thick compressed gasket is between gearbox and block when I have oportunity. Will post results. Made in Poland build thread:
22nd Jan, 2016 at 07:19:13pm
It's only a thin paper gasket before it is crushed - if expect the gear mesh to have more tolerance than that |
22nd Jan, 2016 at 08:56:27pm
So far it's my only explanation unless anyone has a better idea?
Page: |
