Home > For Sale > A few bits
Sorry everyone, new engine purchase fell though, so need to hang onto it for the moment. Few bits can be lost though.
Complete metro turbo engine, with braided oil feed, cossie intercooler, fuel pump, pressure regulator and distributor, no idea what there worth at the moment, will have a think Sold as requiring a rebuild.
1275 turbo block, crank, rods and 20831 originalturbo pistons. covered 5k miles since being fitted with new rings, and has brand new bearings, low milage mpi cam6232 crank and arp rod bolts. I pinched the crank for another engine hence brand new bearings. £250
Water pump new, no bypass- £10
1275 push rods straight. £10 a set
various standard slot drive cams, in good order for reprofiling £10 each.
A-plus rods £25
James
Edited by minimole23 on 2nd Feb, 2016.
Stig
Member #: 694
Shropshire
Does the complete turbo setup include a carb?
If so would you consider splitting the carb inlet manifold and fuel pressure regulator?
That didn't take long. The turbo set will be unbolted from the engine, so includes carb, plenundunnenm, and turbo.
thejefinabox
Member #: 9597
If you do split, I'd be interested in the gearbox and BMW head
ppinno
Member #: 10088
West Sussex
What condition is everything in, in the metro turbo set up? I guess it is "complete" meaning everything you need to go? Apart from pistons etc
The set up will be unbolted from a 30 year old metro turbo engine that I have had running on the floor once. Turbo should be ok, but the carb I would expect to rebuild due to ageing seals. I will post photos of everything this weekend.
Parts now listed invidually
Adam_R
Member #: 1938
near Dundee
what sort of price for the complete turbo engine?
J_W1985
Member #: 11257
PM'd
I said I'd do it, there's no need to remind me every 6 months!!
kezzboycat
Member #: 10371
leicestershire
Pm u about the alternator
I never knew little alternators wet in such demand! Will respond according to messages tomorrow, thanks
hughesmarkie
Member #: 1197
Dublin Ireland
And pics of the Maniflow manifold and twin box exhaust system?
Tks
