Page: |
Home > Beginners Tech > fabricating a turbo manifold | |||||||
43 Posts Member #: 9608 Member Lincolnshire |
7th Jan, 2016 at 09:27:16pm
Hello all
7th Jan, 2016 at 09:34:29pm
it dosent,
3588 Posts Member #: 655 Post Whore Northern Ireland |
7th Jan, 2016 at 09:40:26pm
Turbo manifolds do not have to look pretty to be very functional.
7th Jan, 2016 at 10:52:20pm
I know people on here are looking at longer, equal length runners and I don't doubt there're gains to be had; But until they're built, tested and proven, you won't go wrong copying the Mirage. Edited by PhilR on 7th Jan, 2016. |
11046 Posts Member #: 965 Post Whore Preston On The Brook |
8th Jan, 2016 at 12:01:15am
There are easy gains to be had with longer and equal length branches, but when you can easily over perform the engine as far as grip and handling is concerned, the log type manifolds are more than adequate.
8th Jan, 2016 at 01:54:33am
I'd really hope a better manifold would give better off boost performance and boost sooner.
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
8th Jan, 2016 at 07:14:47am
Metro turbo manifold seems more than adequate for most folks with over 200bhp available - and with less time spent in the workshop it means you are on the road quicker and enjoying that great feeling as the boost comes up. |
8th Jan, 2016 at 08:41:32am
Also,
8th Jan, 2016 at 12:06:25pm
On 8th Jan, 2016 PhilR said:
I'd really hope a better manifold would give better off boost performance and boost sooner. If the gains were just at peak bananas, then I can't see the point either. Depends on your definition of better ? Better for spool may not mean better for power 9.85 @ 145mph
8th Jan, 2016 at 01:47:15pm
On 7th Jan, 2016 benspickup said:
On my N.a mini engine, it's important to get the exhaust manifold pipes all similar or the same lengths. The theory would suggest that the same benefits of fitting an LCB on an NA engine can be attributed to a tuned length turbo manifold. I've seen enough evidence to convince me that this is a very cost effective aproach and will yield more performance gain per pound spent than almost any other mod, particularly if you have the tools and skills to make it yourself. I don't agree with the approach that the metro turbo manifold or a log style manifold is good enough. That's the same as saying that a standard head is good enough. You can gain as much power from a tuned length manifold as a modified head. Neither do I agree that the engine will make too much power. What utter bollox. You can just turn the boost down to a safe level and glow in the knowledge that you are running a higher VE than the other guys. No need to brag, the numbers will speak for themselves. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
8th Jan, 2016 at 03:28:02pm
I'd really hope a better manifold would give better off boost performance and boost sooner. If the gains were just at peak bananas, then I can't see the point either. Depends on your definition of better ? Better for spool may not mean better for power Not everyone's goal is more power; I want a quick road mini that's still enjoyable on a morning commute. If that's Paul's findings, then yes, I would call that a better manifold. Paul, any updates on the side-mount? Any data, a VE table? Edited by PhilR on 8th Jan, 2016. |
8th Jan, 2016 at 04:09:51pm
No data, just an opinion. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
7265 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
8th Jan, 2016 at 04:19:49pm
Wintersurfers car makes much more power than mine (when running the same boost). The only major difference is the long exhaust manifold (a chopped about LCB). He even has less cc's than me.
Edited by theoneeyedlizard on 8th Jan, 2016. In the 13's at last!.. Just |
8th Jan, 2016 at 08:21:16pm
Even F1 cars have used log manifolds to good effect in the last few years. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
8th Jan, 2016 at 09:17:48pm
The winners use tuned lengths.
8th Jan, 2016 at 09:34:49pm
I fail to understand how people who recommend using a well modified cylinder head don't seem to see any benefit in a well designed exhaust manifold. It all works on the same principle and they are well proven.
8th Jan, 2016 at 09:48:53pm
Case in point of why no one posts on this forum anymore. Just my opinion. On 26th Oct, 2004 TurboDave16v said:
2974 Posts Member #: 10749 Post Whore lowestoft suffolk |
8th Jan, 2016 at 09:50:26pm
On 8th Jan, 2016 Paul S said:
The winners use tuned lengths. Ooooooof... what models engine bay does that beaute live in? On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!! 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
450 Posts Member #: 10396 Advanced Member Formerly mk2turbo Stoke-on-Trent |
8th Jan, 2016 at 10:00:27pm
That's the v6 f1 engine I believe, so Hamiltons |
8th Jan, 2016 at 10:07:06pm
Not in the first year they didn't
8th Jan, 2016 at 10:10:33pm
On 8th Jan, 2016 Sprocket said:
Case in point of why no one posts on this forum anymore. Just my opinion. Just to be clear, do you mean that my post would turn off people from posting here? If so, that says more about others than it does about me, but that's just my opinion. |
8th Jan, 2016 at 10:16:01pm
I could reply with a come back, but I can't be arsed On 26th Oct, 2004 TurboDave16v said:
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
8th Jan, 2016 at 10:17:02pm
Case in point of why no one posts on this forum anymore. Just my opinion. Really Col, it's just a bit of an interesting debate as far as I can see.
8th Jan, 2016 at 10:24:09pm
By the way I'm not arguing against a fancy manifold. But cost and packaging etc may mean a simpler manifold is the best solution in many cases.
8th Jan, 2016 at 10:30:35pm
wait a minute why argue about the type of manifold rather than the guy is wanting to keep the turbo behind the engine and not cut the fire wall
Page: |
