Page: |
Home > General Chat > what dolly and hammer? | |||||||
![]() 1750 Posts Member #: 10190 Post Whore belgium |
24th Dec, 2015 at 03:13:26pm
done already allot of bodywork now but came to a point that my normal set of bench hammers ( with round of corners) and metal tubes no longer are sufficient for what i want to do. what shapes and type of hammers should i go for?
24th Dec, 2015 at 04:06:42pm
Ive been a panel beater/fabricator for 25 years Aston Martin trained and I have one flat faced planishing hammer which rarely gets used. I dont have any dollies - theyre for girls - handweights are for men, mine are just random blocks of steel that Ive filed into various shapes for what Ive needed at the time.
I seriously doubt it! |
24th Dec, 2015 at 04:22:10pm
a flipper i thinck my granddad once made one out of a leave spring from an old jeep. do the blocks need allot of rounding? so flat sides are better then the rounded onces? i also see allot of pointy hammers etc? you can do anything if you set your mind to it...
24th Dec, 2015 at 04:28:57pm
The faces should always have a slight curvature rather than fully flat.
24th Dec, 2015 at 04:33:11pm
http://www.ebay.co.uk/itm/Sealey-CB58-Pane...KoAAOSwBahU~jBb
24th Dec, 2015 at 04:37:04pm
On 24th Dec, 2015 paul wiginton said:
The faces should always have a slight curvature rather than fully flat. Leaf spring is best for flippers you can do anything if you set your mind to it...
24th Dec, 2015 at 05:34:26pm
That set looks ok I seriously doubt it! |
Page: |
