Page: |
Home > Non-Mini Discussion > 2008 520d M sport suspected chain snap? :-( | |||||||
2974 Posts Member #: 10749 Post Whore lowestoft suffolk |
6th Nov, 2015 at 10:20:00pm
Nothing gets past Dave lol NOTHING GETS PAST ME!! 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
6th Nov, 2015 at 11:11:14pm
Never had it on the diesels but im pretty comfortably into double figures on skipped chains on the 4 cylinder petrols.every sigle time i have had one in with a cam sensir fault code its the chain. That said i have never yet had one do valve damage as they only jump a tooth or two. turbo 16v k-series 11.9@118.9 :)
6th Nov, 2015 at 11:15:04pm
Thanks for quick reply.. sounds promising then? You say skip a tooth? So it may not be actually snapped then? He said there was no noise at all On 24th Oct, 2015 jonny f said:
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
6th Nov, 2015 at 11:15:43pm
Certain engine codes of the 2.0 diesel are known for this problem. The timing crank sprocket is machined as part of the crank, it wears out then skips the chain. I'm sure a Google will yield more info.
6th Nov, 2015 at 11:23:44pm
Mm thats pretty grim, on the petrols the sprockets are all replaceable and come in a kit with the chain and guides n that. turbo 16v k-series 11.9@118.9 :)
24 Posts Member #: 6538 Member Angus, Scotland |
7th Nov, 2015 at 11:30:24am
A lad at work has just had his chain tensioner replaced in his 320d as recall from bmw...
4890 Posts Member #: 1775 Post Whore Chester |
7th Nov, 2015 at 11:47:07am
The tensioner is a common fail on the 2.0l d. I run a supercharger and I don't care the TB is on the wrong side.
Page: |
