Page: |
Home > Technical Chat > Which fuel pump for super charger | |||||||
9 Posts Member #: 10951 Junior Member |
4th Nov, 2015 at 03:39:24pm
Just went to start my engine after my Podifold install and I have realised my old silver top facet 4.5 psi pump isn't pumping ( been left standing empty for 12 months). So, going to need a new pump. Just wondered what would be the best if I run the charger up to about 9 psi on boost, because the comp facet silver top goes to about 6psi. What do you turbo chaps use? Cheers
Edited by HUBBAHUBBA on 4th Nov, 2015. |
7265 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
4th Nov, 2015 at 04:02:18pm
Unless your setup is blow through, it will have completely different requirements to a turbo build.
In the 13's at last!.. Just |
32 Posts Member #: 10958 Member |
4th Nov, 2015 at 06:49:38pm
Its blow through, using a turbo regulator. Edited by HUBBA.HUBBA on 4th Nov, 2015. |
6745 Posts Member #: 828 Post Whore uranus |
4th Nov, 2015 at 08:49:16pm
just any old fuel inj pump , i think mine came off a cavalier .need a good 8mm return line too .
4th Nov, 2015 at 09:47:01pm
Got an 8mm return. What sort of psi would an injection pump go to, 20psi? As I m running a metro turbo hif44, what did the metro run at I wonder |
5th Nov, 2015 at 09:26:21am
injection pumps can make 60 psi+,
5th Nov, 2015 at 09:59:20am
Blimey. How was that working?
5th Nov, 2015 at 04:43:49pm
What psi would it go up to? |
5th Nov, 2015 at 11:22:17pm
More than enough for your supercharger setup. The pump will not be your limiting factor.
6th Nov, 2015 at 06:45:50pm
Thanks but I've ordered a sytec pump now |
Page: |
