Page: |
Home > General Chat > Teflon braided hose and oil feed take off location | |||||||
2nd Nov, 2015 at 06:12:58pm
Hi
My build thread..
2nd Nov, 2015 at 10:03:08pm
I dont think you NEED to use PTFE hose. Best check the alternative is good quality oil resistant stuff tho.
3591 Posts Member #: 655 Post Whore Northern Ireland |
3rd Nov, 2015 at 12:01:55am
Teflon generally has a higher temp rating, so is better for the turbo oil feed. Either that or metal or proper hydraulic type hose.
3rd Nov, 2015 at 07:46:45am
Ok think I'll just teflon for both to be on the safe side.
My build thread..
3rd Nov, 2015 at 08:50:16am
a take off between the block and filterhousing is fine,
3rd Nov, 2015 at 06:43:36pm
Ok that's great.
My build thread..
3rd Nov, 2015 at 08:18:40pm
That would work yes, but why? You can just take the feed out of the oil pressure take off hole as standard and save a few quid?? |
3rd Nov, 2015 at 08:34:05pm
What one slater?
My build thread..
Site Admin ![]() 9404 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
4th Nov, 2015 at 09:43:21am
if you use the filter head from DSN and install with an oil cooler, then you will be reading the oil temp after the cooler not before. Not ideal. Team www.sheepspeed.com Racing
4th Nov, 2015 at 03:03:26pm
The Dsn one would be OK I mean. The takeoff is on the filtered side.
4th Nov, 2015 at 04:20:28pm
On 4th Nov, 2015 Jimster said:
if you use the filter head from DSN and install with an oil cooler, then you will be reading the oil temp after the cooler not before. Not ideal. I'm using a mocal sandwich stat plate for the oil cooler Jim. It screws on between the filter and the filter housing. Thanks Josh My build thread..
Page: |
