Page: |
Home > For Sale > R5 GT T2 with stainless steel manifold | |||||||
774 Posts Member #: 6724 Post Whore Wootton Bassett |
17th Oct, 2015 at 08:01:35am
R5 GT T2 with stainless steel manifold and downpipe. Plus sample tubes for dual widebands. If used with a carb the MG Metro inlet will fit, but will need cutting to clear the sample tubes or the sample tubes will need removing. Good working order - £300
167 Posts Member #: 11091 Advanced Member |
17th Oct, 2015 at 08:50:46am
I'll take it :) |
17th Oct, 2015 at 08:52:22am
But what are the sample tubes about I don't understand? |
17th Oct, 2015 at 10:09:41am
It's built specifically for port injection and dual widebands.
Edited by Paul S on 17th Oct, 2015. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
17th Oct, 2015 at 12:53:53pm
On 17th Oct, 2015 Will said:
But what are the sample tubes about I don't understand? They allow you to monitor any fuelling difference between inner and outer cylinders (outers tend to run a little leaner). So if you have fuel injection you can compensate for the difference. You need to sample before the turbo so you can get either just the inners or outers. You can't just bolt the lambda gauge in because pressures/ temperatures will be too extreme. Hence you siphon off a little bit with the sample tubes. On a carb'd car it would be interesting information (and I'm sure a few of us would be keen to see the spread) but it's unlikely you could do anything to correct it. So you can just blank them off or cut them off altogether. Edited by dan187 on 17th Oct, 2015. |
17th Oct, 2015 at 07:17:05pm
If only I could afford this :( |
61 Posts Member #: 6135 Advanced Member bristol |
18th Oct, 2015 at 09:29:48pm
Hello, is this still for sale? |
19th Oct, 2015 at 06:53:23am
On 18th Oct, 2015 yastra said:
Hello, is this still for sale? It is indeed. |
23rd Oct, 2015 at 11:02:52am
Any new takers? Edited by dan187 on 23rd Oct, 2015. |
23rd Oct, 2015 at 02:29:29pm
Dude I may be able too but sont hold out need my mx5 to sell and I'll see what cash I've got after |
23rd Oct, 2015 at 02:30:18pm
Also dose it Nedd a box to fit it? |
71 Posts Member #: 5754 Advanced Member Bridport Dorset |
24th Oct, 2015 at 01:21:54pm
Does it need bulk head mods |
27th Oct, 2015 at 12:42:41pm
On 23rd Oct, 2015 Chalkie said:
Also dose it Nedd a box to fit it? On 24th Oct, 2015 dave-88_123 said:
Does it need bulk head mods No, it should fit without mods/ box. |
1 Posts Member #: 11244 Junior Member |
28th Oct, 2015 at 08:45:26pm
Did this sell in the end? |
29th Oct, 2015 at 12:53:29pm
still for sale |
144 Posts Member #: 10557 Advanced Member |
29th Oct, 2015 at 03:47:09pm
PM'd Double-Blind experiment, N:
3rd Nov, 2015 at 10:00:52pm
Pm'd
Page: |
