Home > Show Us Yours! > Hot engines/ overheating problem
Will
Member #: 11091
Had abit of an overheating problem this evening
Will
Member #: 11091
Having trouble with attachments
Www.Yogile.com/willsmini
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
shit man thats serious everyone ok?
Will
Member #: 11091
Yep all good
Commando roll'd out 😄
Will
Member #: 11091
Yep all good
Rammie2000
Member #: 10190
belgium
Shame for the car. Lucky you got out.
Earwax
Member #: 10368
Australia
ouch, good to see you are okay. Nasty
Will
Member #: 11091
Added some more after pics 😄
All saveable too
Gutted man, that's 100% an electrical fire from where it is situated
Will
Member #: 11091
From what I can see the pipe leaving the mechanical fuel pump to the carb had split
The car sort of stuttered then died while driving, having just jump started it I thought it was the battery and as it was still rolling dropped the clutch in second a few times then woomfh straight up
So basically while it was still running off the fuel in the float bowl it had covered the bulkhead and hot lcb in fresh fuel
I then helped it some more by trying to bump it 😄
Think the fact the fuel tank was empty and just filled it up didn't help so could have been some crap blocking the line or just an old rubber hose
Edited by Will on 6th Oct, 2015.
Will
Member #: 11091
Just bought it too 😄
But your right Carl, it had some shocking I wiring too
Luckily is due a paint job aswell
Jay#2
Member #: 648
Northern Ireland (ex AUS)
On 5th Oct, 2015 Will said:
Yep all good
I know I shouldn't be laughing but the mental image I have of someone rolling out of a flaming mini. Your in good spirits about it, I'd be gutted.
On 7th Nov, 2008 Nic said:
naeJ
m
PhilR
Member #: 10034
Birmingham
Damn, that looks bad but I suppose could have been much worse. How long was it burning?
As Carl says, it does look electrical. Any smell of petrol recently?
Edited by PhilR on 6th Oct, 2015.
D4VE
Member #: 10749
lowestoft suffolk
Wow! Nice one for keeping in good spirits, atleast ya ok
Nothing gets past Dave lol
Will
Member #: 11091
Wasn't electrical was fuel pipe related
I'm mainly glad I got out ok, then I was pleased the car is saveable as at the time it looked like it was gunna tear through the lot
Especially with the wind blowing it towards the rear of the car
And my iPhone 6s that was on the passenger seat survived the fire & the high powered water too lol
Yeah is abit more work but nothing a few days and couple of ££ can't fix
Could have been a lot worse and a damn site more expensive!
Will put a project thread 😄
Fuel on a hot manifold will not ignite, most likely the vapours were subject to a spark somewhere
I've experienced this very thing with a split hose coming off the mechanical fuel pipe and vapours igniting off a halogen lamp so its quite possible and looking at the damage, if it had been electrical related I would have expected a great deal more fire damage around the bulkhead before it took out the carb, filter housing etc
all in all, you've been lucky not to loose the car
evolotion
Member #: 83
Glasgow, Scotland
petrol autoignites at just under 300 degrees. I'v experienced similar as well tho thankfully just brake cleaner and only a little squirt as was cleaning up an oil dribble
EDIT glad your ok, that fuel line was my second biggest "fear" in the mini, right after the positive battery lead chewing thro the boot floor lol
Edited by evolotion on 7th Oct, 2015.
Denis O'Brien.
