Home > Help Needed / General Tech Chat > k1100 build cad files wanted
stuart3925
Member #: 11213
Hi Guys,
I,m just starting a k1100 build and wanted to know if any one had a cad file of the aluminium end plates so i can get them laser cut?
Stuart.
I'm sure you do, how about you do it the hard way and start form scratch with a measuring device, nobody will give you their hours of work FOC,good luck with the search
Hear here!
16vmini
Member #: 5037
aye , just get on and make it by hand
my dad just cut ali by hand , also did not do any major CNC work , just made individual oil seal holders
http://bmw.16vmini.co.uk/?m=201404
stuart3925
Member #: 11213
looks like i'm cutting one myself then. unless any one sells them outside of a complete kit.
I just measured the hole centres, drilled them first. Bolted the plate to the head and scribed round the head and cam cover of the outside dimension. The made a marking tool up to mark the centre of the cam holes..
TurboDave16V
I have a CAD file of a bolt if you want?
I don't need a cad file for a bolt, I can make one form memory,lol
