Page: |
Home > Wanted > trigger wheel bracket | |||||||
25th Sep, 2015 at 04:27:46am
HI, I am after a trigger wheel bracket for the vr sensor. This needs to sit on the end mount bracket rather than anywhere else.
6549 Posts Member #: 1149 #1 Basshunter Fan Force Racing ICT Dept Manager Miglia Turbo Am frum Yokshyer tha noes! |
25th Sep, 2015 at 08:20:05am
Bottom et page
26th Sep, 2015 at 04:11:12am
thanks, but I need it to sit on the engine mount rather than the timing cover as I have a twinky conversion. something like this https://www.google.co.uk/search?q=mini+vr+s...9g3MhqtFWIDM%3A |
11046 Posts Member #: 965 Post Whore Preston On The Brook |
27th Sep, 2015 at 07:57:35am
Most of those are DIY jobs. Some may use a universal bracket but will still be DIY
Edited by Sprocket on 27th Sep, 2015. On 26th Oct, 2004 TurboDave16v said:
27th Sep, 2015 at 12:07:21pm
On 27th Sep, 2015 Sprocket said:
Most of those are DIY jobs. Some may use a universal bracket but will still be DIY The bracket I made is in that lot, simply a piece of angle and flat bar available from B&Q. The sensor is from a zetec ford fiesta, likely other fords as its quite common. Thanks, just trying to save a little time, I have not touched the car in 8 months :( |
Page: |
