| Home > Technical Chat > Advice for Turbo Build Spec please | |||||||
55 Posts Member #: 8837 Advanced Member Warwickshire. |
18th Sep, 2015 at 01:19:18pm
So after finishing my R1 fwd track day mini last year I am now moving onto restoring my other mk3 mini. The build brief is to have a fast, comfortable, quiet(ish) daily driver that can cruise happily at motorway speeds that is capable of getting me to the N`Ring and back.
1976 Mini 1000 FWD R1 - 13.2@104
18th Sep, 2015 at 01:26:57pm
Looks very well spec'd to me.
Edited by theoneeyedlizard on 18th Sep, 2015. In the 13's at last!.. Just |
![]() 537 Posts Member #: 8926 Post Whore Sheffield |
18th Sep, 2015 at 02:08:13pm
As above if you can go for a 20% or RTS clutch along with megajolt.
18th Sep, 2015 at 03:48:23pm
Yup SC box would be a good shout, helical drops should manage though. If something is worth doing, it's worth doing half of. |
167 Posts Member #: 11091 Advanced Member |
18th Sep, 2015 at 04:29:35pm
Wouldn't worry about the crank so much as there's little evidence of them actually being tougher unless you've already got one
20th Sep, 2015 at 03:12:32pm
Thanks for the replies chaps. I have no experience of megajolt but know DTA fairly well so I may bring that into the budget as I suppose knock control is a nice cushion to have over a dizzy.
20th Sep, 2015 at 04:49:56pm
Sc box and helical drops is the best compromise as it goes quiet in top when it drives straight down the main shaft. If something is worth doing, it's worth doing half of. |
20th Sep, 2015 at 04:54:45pm
We ran helical box with s/c drops in the metro van with about 150bhp. The bearings suffered, looked like we we're on borrowed time when it came apart. On 11th Feb, 2015 robert said:
20th Sep, 2015 at 08:12:01pm
Thanks that's great info. So straight cut gears in the box to take some load off the bearings & as you say the helical SC drops will keep it quiet on the motorway.
Edited by duds100 on 20th Sep, 2015. 1976 Mini 1000 FWD R1 - 13.2@104
20th Sep, 2015 at 08:18:21pm
From personal experience, and reflecting other comments, i'd go for sc gearkit, particulary with the potential power you'll be able to push out on that spec |
20th Sep, 2015 at 08:24:19pm
I Ran SC CR gears with a 3.1 diff and extra sound deadening (5-10 KG) in the cabin. The car was great once moving and cruised quietly on the motorway and otherwise pretty quiet (with the windows up) BUT because of the taller 1st gear, driving at stop start and slow speed was tedious.
Edited by PhilR on 20th Sep, 2015. |
21st Sep, 2015 at 12:25:12am
ill put my two cents in the hat
21st Sep, 2015 at 10:20:31am
As said once you get it moving with a sccr set should pull like a train through the gears. Sccr set is perfect for an fi engine once you get it going |
21st Sep, 2015 at 11:05:45am
I've got at 3.2 on 10's and don't find it an issue getting off the line. If something is worth doing, it's worth doing half of. |
21st Sep, 2015 at 01:00:05pm
Ok so I am going to back off the spec a little to assist gearbox reliability and mean not having to go SC.
21st Sep, 2015 at 01:39:35pm
Go for mapped ignition regardless of specification! Makes a much nicer drive.
21st Sep, 2015 at 02:55:24pm
Thanks John. Hopefully the combination of a GT1752 & mappable ignition should give me a nice torque curve with some decent low end shove to pull the 2.7CWP.
21st Sep, 2015 at 04:17:42pm
Start with the BDD and work from there. If something is worth doing, it's worth doing half of. |
22nd Sep, 2015 at 06:44:35am
Great, thanks. 1976 Mini 1000 FWD R1 - 13.2@104
