Page: |
Home > Wanted > Allspeed Subframe | |||||||
6549 Posts Member #: 1149 #1 Basshunter Fan Force Racing ICT Dept Manager Miglia Turbo Am frum Yokshyer tha noes! |
10th Sep, 2015 at 09:19:12am
Chaps im after an allspeed subframe, Ive tried on 16v Mini Forum but not had much luck.
264 Posts Member #: 11029 Senior Member Crewe |
10th Sep, 2015 at 10:17:49pm
Why dont you call rob at allspeed and purchase one ? Outside the box |
10th Sep, 2015 at 10:33:08pm
There too far above my budget im afraid. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
37 Posts Member #: 5037 Member |
11th Sep, 2015 at 12:26:12pm
sorry , but for what engine ? |
11th Sep, 2015 at 12:34:16pm
16szr I think it is, Small block basically. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Sep, 2015 at 12:45:10pm
Do you have one for sale pal? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Sep, 2015 at 04:30:31pm
Why not make your own if your on a budget it's box section I had one for my vtec use the mini towers get the engine where you want and make mounts etc to suit v8 landrover engine mounts are good to mount stuff on i did similar with my haynes roadster bolts and plates away you go. Outside the box |
11th Sep, 2015 at 04:31:45pm
Driveshafts etc can be shortened and made local machine shop or prop specialist will help out not too much expense Outside the box |
11th Sep, 2015 at 04:31:52pm
Thats my next option. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Sep, 2015 at 04:56:09pm
Really thats the best option its not hard just take your time and measure 12th-ty times cut once and remember its metal it can be chopped and started again. Id suggest making a jig and taking some standard measurments for tie bars and go from there. Outside the box |
Page: |
