Home > Technical Chat > Request for Turbo Engine Specs assistance
ClubmanTurbo
Member #: 1213
Cyprus
Hello!
I am about to recondition my Turbo Engine and I would like your suggestion on the engine specs befor ei place my order to MED. I am targeting to a road-weekend-smooth driven Mini of around 130bhp.
Please let me hav your opinion about parts that i may consider to upgrade in order to achive desired power and reliability OR degrade to save some costs.
- Capacity: 1293cc
- CR: 8.8:1
- Boost: 12psi
- Valves: In 35.6mm, Exh. 30mm. Stainless steel with MED road springs
- Valve Guides: MED std bronze
- Chamber:25cc
- Pistons: Omega Cast +20 10cc
- Dublex timing chain kit
- Camshaft: Avonbar Phase 2 (or suggest alternative Piper Road Camshaft from MED)
- Roller Rockers: 1.3 OR 1.5 ?
- Front Mounted Intercooler - size suggestions..?
- Cylinder Head Gasket: is the BK450 sufficient or should go more steel gasket?
- Crank/Clutch/Gearbox/Diff: All standard for the moment.
Thank you for your imput and advises!
George
Clutch will need uograding, look at an RTS. And I'd suggest a cross pin diff in the box.
hazpalmer
Member #: 9038
Carlisle, Cumbria
Rockers wise, most people just use standard. You can fit the 1.3's if you've got the money. And people who have used 1.5's with the phase 2 cam say its too "peaky"
Intercooler, go for the biggest one you can fit!
t@z
Member #: 452
Chester, UK
i ran 10psi in my 1293. all bottom end was just normal ish stuff. cast pistons, nor,al crank and from what i know std clutch, i just got the head worked by turbo phil and i made about 125 bhp. spec wise it wasnt anything special and the thing was bomb proof.
www.twitter.com/lilpinkiy
ClubmanTurbo
Member #: 1213
Cyprus
t@z: no intercooler?
t@z
Member #: 452
Chester, UK
ah yeh i had an intercooler, one of these in the front behind the grill http://www.ebay.co.uk/ulk/itm/301728201423 i also had straight cut drops but probably wasnt needed.
i have a thread on here have a ganders if u wanna see how it was mounted size etc
