Page: |
Home > Beginners Tech > compression calculation for advanced people...?? | |||||||
![]() 1750 Posts Member #: 10190 Post Whore belgium |
6th Sep, 2015 at 08:09:18pm
hy. so i know standard way to calc compresion ( cilinder +head =... etc)
6th Sep, 2015 at 10:01:25pm
this is what i used
![]() 64 Posts Member #: 6668 Advanced Member |
9th Sep, 2015 at 12:49:05pm
Hello, this is one
Racecar spelled backwards is Racecar |
22nd Sep, 2015 at 08:28:37pm
Superb info. Thnx you can do anything if you set your mind to it...
22nd Sep, 2015 at 08:31:35pm
Wich of the 2( dynamic or static) would be the safest to look at when building a turbo engine? Edited by Rammie2000 on 22nd Sep, 2015. you can do anything if you set your mind to it...
22nd Sep, 2015 at 11:36:51pm
im not experienced enough to say what you should do but i will say it how i see it
25th Sep, 2015 at 03:16:39am
I used this one for my k1100 race engine
![]() 4629 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
15th May, 2018 at 08:16:11am
Bringing up an old thread.
15th May, 2018 at 08:53:40am
Sure I've read somewhere about desired maximum cylinder pressures calculated using dynamic CR on here Phil. I can't think who's thread it was though. If something is worth doing, it's worth doing half of. |
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
16th May, 2018 at 09:01:58am
It's a step in the right direction to consider the inlet valve closing in determining the optimum compression ratio. However, it is just one of many factors that determine the temperature in the cylinder at the point of ignition and the potential for detonation. Big subject, many factors involved.
16th May, 2018 at 09:52:30am
somthing that confuses a lot of people is that Dynamic comp ratio numbers are different to Static ones, and not may people have much idea what dynamic compression they need,
16th May, 2018 at 06:16:40pm
Quit a difference indeed. But what is the safe one to follow then? you can do anything if you set your mind to it...
Page: |
