Home > General Chat > Parts Washer Fluid
graemec
Member #: 1424
Carnforth, Lancs
Just picked up a parts washer, don't know how useful it will prove but it was at a price I couldn't pass up.
Has anyone got any suggestions as to the best 'readily available' fluid to use with it?
evolotion
Member #: 83
Glasgow, Scotland
Get some of the proper non flammable stuff kerosine is an obvious choice but some spatter from welding or similar could really ruin your day :(
Surely you can get suitable water based solvent on ebay or the likes. I have a feeling we may have used a swarfega branded product in ours once we got away from "enviroclean" and there daylight robbery.
Denis O'Brien.
mini93
Member #: 2017
Warwick.
Used to have Kerosine at the garage I was at before, mostly cleaning out old manky gearbox casings. Didnt really think of any fire implicatoins as it was in a seperate area. I guess home garage use is a little different.
Does leave a residue on the parts once washed, quick splash of brake cleaner sorts that out though.
David.
I have tried the various water based ones and found them pretty poor. I managed to get hold of some Safety Kleen stuff which is much better, but I think it's just Kerosine really.
graemec
Member #: 1424
Carnforth, Lancs
Fire risk will (hopefully) be minimal as the washer will be in the shed away from any hot works.
Kerosine may be the way to go then, but does it not stink?
I guess any oil based product will leave a film behind - good for preventing flash rust but will need further work if to be painted.
I use paraffin which has worked well from the point of view of cleaning but it leaves a film which generally attracts dust and needs further work as you day if your painting. I like the water based gunk stuff in the past but i'd look about for something else when it comes to changing the fluid
swarfega patio cleaner ( used to be called engine degreaser)
http://www.screwfix.com/p/swarfega-patio-d...aner-5ltr/85114
now i dont have a parts washer but i used this stuff in a bucket, its bloody brilliant, i used it mixed as well as neat
Proper engine de-greaser is best, albeit not overly cheap for the quantity you need for a washer. But it should last a very long time, and will wash off pretty clean with water.
D4VE
Member #: 10749
lowestoft suffolk
Jizer!! *wink*
Nothing gets past Dave lol
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
diesel is currently in mine
tryed the water based type it was rubbish
Rammie2000
Member #: 10190
belgium
I use diesel and works wel. ( let it soak for few days before cleaning)
PhilR
Member #: 10034
Birmingham
I bought some GUNK engine degreaser; Although it works well, I'm convinced its just (expensive) red diesel.
Another vote for diesel, good for cleaning out gearboxes, it just smells a bit.
evolotion
Member #: 83
Glasgow, Scotland
kerosene and diesel have the same flash point, if your washer has a thermostatic ram on the lid make sure it looks servicable if your going to run a flamable fluid :)
Denis O'Brien.
slater
Member #: 1291
Suffolk / Birmingham
We started using Jizer after safety clean refused to sell us thier stuff anymore. It's a little more viscous but still works just fine. Not found anything off the shelf to beat it yet. We used to have a can of comma hyperclean which I remember as being good stuff but not sure if they changed the recipe as this was 15years ago!
D4VE
Member #: 10749
lowestoft suffolk
Cant beat jizer! Had to clean up a van at my old work and the joke of 'theres jiz EVERYWHERE!!' Did not get old at all that day! *happy*
On 31st Aug, 2015 D4VE said:
Jizer!! *wink*
Correct, or any similar de-greaser, you can get them in 25litre drums, or if the washer is smaller 1 gallon drums
Gunk is literally a waste of money
tadge44
Member #: 2500
Buckinghamshire
And it stinks !!
graemec
Member #: 1424
Carnforth, Lancs
Thanks guys, some good suggestions.
I don't fancy derv as everything stinks afterwards, gunk is probably similar.
Might try Jizer though - does that smell OK?
D4VE
Member #: 10749
lowestoft suffolk
It does have a smell! But not the worse ive used.. dried my hands out big time but thats my own fault! Ieft the most oily cacky gear selector in the stuff for a hour then blasted it off and it just all came off instantly.... all over my face
Alex
Member #: 1851
Woolavington, Zummerzet
Another vote for Jizer, I have it in both of my washtanks.
