Home > General Chat > What size fuel pipe
Ryancarlin1
Member #: 11056
South yorkshire
What size fuel pipe are people running? Is 10mm feed and 8mm return okay?
8mm feed and 10 mm return ( return should be bigger or at least the same imo)
8mm feed is way more than enough
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
used 5/16 (8mm) for both on mine
i think its not the line size but the volume getting to the engine ie small dia lines at high pressure or large dia at low pressure could be the same volume for a given time also routeing and fittings/sizes could bottle neck things
personally I'm running 10mm OD copper return and 8mm OD supply on mine; I understand the preference would be for ID sizes but it works for me
Well I have been using 8mm both ways and it looks to have worked ok for me.
coopdog
Member #: 9628
Yeah I have 8mm id there and back
Ryancarlin1
Member #: 11056
South yorkshire
Would 8mm both ways be good enough for a build that's hopefully going to be pushing 180 bhp?
D4VE
Member #: 10749
lowestoft suffolk
^^^ obviously ^^^
Nothing gets past Dave lol
With ease.
