Home > Beginners Tech > Verto clutch & flywheel - options
Tuctuc
Member #: 10894
Lancashire
I'm getting my crank polished and balanced so obviously need the flywheel in its finished state to do this.
The turbo verto clutch / flywheel I have are probably original so recommendations please on what to replace?
A) new turbo clutch and plate - maybe not man enough as aiming for 130nanas min
B) HD cover and AP rally plate - should cope, plus cheapest option but unsure of quality / types from minisport /spares, although med list a cover 20% uprated from turbo spec. Recommendations? Do the 190mm plates fit early 180mm verto?
C) lightened flywheel and HD clutch with AP plate - med again list but pricey. Do you guys run these, if so how do you find them as I've been told to stick with std flywheel?
If I go with b) I've got a donor clutch for rts should it not cope or giggle button is turned up in the future, what do you reckon
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
if you all ready have the verto type then id say to collect another and build the RTS
just my thoughts
have a read
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10207
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=437563
I'm sure all verto's will take a 190mm plate,
I'd deffo go with the RTS, al long as what you have is an AP verto.
its also well worth lengthening the verto arm a bit with a strong RTS,
fixitphil2
Member #: 10945
scarborough/ northyorkshire
iv got the verto 20% uprated cover with paddle plate on mine.i get slight clutch slip some times then can be ok for a while, thats with 10psi 134 bhp 125 torque,iv got all parts to do an rts clutch this winter as wanting to turn boost up.
I'd personally go straight for the RTS. I'm running a standard turbo plate and its been fine so far with 15psi
Tuctuc
Member #: 10894
Lancashire
Thanks guys, seems to be a big tolerance on what some std turbo clutches can handle, guess it depends on the spring thickness.
I think I'll get the crank balancing done with std clutch and flywheel (may lighten it a little) then build an rts when I'm ready and get that rebalanced
PhilR
Member #: 10034
Birmingham
On 31st Aug, 2015 Joe C said:
...its also well worth lengthening the verto arm a bit with a strong RTS,
Any idea how long you can extend the clutch arm?
jonny f
Member #: 9894
Dorking
Use a metro cable clutch arm and cut it to suit the pushrod.
That's what I've done and seen done on here.
basically this ^^
I pulled the rubber out and cut a slit downt the cable clutch arm and put a couple of bearings in the end,
Robert chopped the end off of a spare std verto arm, and filed/ fettled it to be bolted onto another std verto arm.
you can go about 1/3 longer IMO
Rammie2000
Member #: 10190
belgium
any picks of these mods ( am bussy building an rts to)
PhilR
Member #: 10034
Birmingham
Tuctuc, I was thinking the same thing but read the RTS build thread several times last night and IMO would be a shame to have to pull the clutch / engine for something so simple, especially if there's a fairly good chance it's needed. I started my RTS build this morning and it's as simple as it looks and now all but assembled (just waiting for the bolts).
The Metro arm option sound good, but I need it done ASAP so just went at it with a MIG and angle grinder. It's extended a third (about 18mm). Does it look right? I suppose I have to tweak the slave cylinder mount, or will the pushrod still work at an angle?
*Clapping*
that looks great!
yeah, you'll have to frig around with the mount, I stuck some washers under mine, dont forget to support the rear of the slave too, or it'll flex
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=424802
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i think you better amend that part number..
looks like another top job
Yo-Han
Member #: 3228
North of the Netherlands
That looks very nice Phil!
What bolts did you go for; tapping the plate or straight through and nut on the other side?
Dazed and Confused....
