Page: |
Home > General Chat > Minispares external alloy door hinges | |||||||
450 Posts Member #: 10396 Advanced Member Formerly mk2turbo Stoke-on-Trent |
26th Aug, 2015 at 08:54:23pm
I bought some of these and have had them fitted to the mk2 for a couple of months now. Recently I have been struggling to line up the drivers door as it keeps dropping off towards the rear, so tonight I took the hinges off and noticed quite a lot of play in them. Got a couple of videos
Edited by Callum on 26th Aug, 2015. |
![]() 1750 Posts Member #: 10190 Post Whore belgium |
26th Aug, 2015 at 08:58:22pm
i bought some for the mk1. hope doesnt do the same. you can do anything if you set your mind to it...
![]() 696 Posts Member #: 10034 Post Whore Birmingham |
26th Aug, 2015 at 09:32:02pm
The play you've tested for is not a problem... You need to check for play by pulling the two halves apart (top hinge) and pushing them together (bottom hinge) as this is how they're loaded when in place
Edited by PhilR on 26th Aug, 2015. |
Page: |
