Page: |
Home > General Chat > wanting to change drivelines pot type to Hardy-Spicer confusion | |||||||
18th Aug, 2015 at 10:41:03pm
my question is how do i identify the drive shafts?
Edited by Turbo This.. on 28th Aug, 2015. |
450 Posts Member #: 10396 Advanced Member Formerly mk2turbo Stoke-on-Trent |
19th Aug, 2015 at 07:02:53am
The diff side covers on the hardy spicer have a larger internal diameter than the pot joint and yoke (rubber u joint setup). So you would either need the hardy spicer covers part 22G420 or a couple of these which allow you to use the pot joint diff covers
28th Aug, 2015 at 12:59:25am
im going to go dig out the drive shafts that i have and measure count the splines after lunch
28th Aug, 2015 at 03:41:15am
so got a few sizes on the rubber type shafts it would be awesome if they are the same as uni joint type
28th Aug, 2015 at 04:20:17am
ok so looking on the net and counting splines from those pics it seems the rubber jount and hardy type use the same shafts? |
28th Aug, 2015 at 12:31:45pm
There is nothing complicated about this and its been done to the death.
28th Aug, 2015 at 11:07:18pm
ahh now i see
28th Aug, 2015 at 11:19:35pm
We are missing one very important point. The pot joint output shaft is a completely different spline to the hardy spicer output shaft.
28th Aug, 2015 at 11:37:50pm
ok so im installing a new ATB diff that has pot joint type output splines
28th Aug, 2015 at 11:59:05pm
In this case there are only two options open to you. Keep the pot joints or, buy the Swiftune adapters. On 26th Oct, 2004 TurboDave16v said:
29th Aug, 2015 at 09:01:13am
Page: |
