Page: |
Home > Beginners Tech > Problem with MJ | |||||||
14 Posts Member #: 11180 Member |
14th Aug, 2015 at 06:08:24pm
Hi everyone,
6549 Posts Member #: 1149 #1 Basshunter Fan Force Racing ICT Dept Manager Miglia Turbo Am frum Yokshyer tha noes! |
14th Aug, 2015 at 06:17:28pm
Bad Battery 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Aug, 2015 at 06:29:02pm
battery is fine... the engine has power to start but it doesn't start. I think that the MJ is the problem but I don't know how I will could fix the map of megajolt |
67 Posts Member #: 8956 Advanced Member Algarve/Portugal |
14th Aug, 2015 at 07:52:32pm
Check cranking Advance. |
14th Aug, 2015 at 08:03:57pm
how check that? |
7265 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
14th Aug, 2015 at 08:53:44pm
There's a separate window for cranking advance. Think it's in one of the preferences menus. In the 13's at last!.. Just |
18th Aug, 2015 at 06:35:43pm
of course, but anyone else have a perfect config. of MJ? |
18th Aug, 2015 at 06:50:40pm
Perfect for what though? Every setup is different. In the 13's at last!.. Just |
90 Posts Member #: 7555 Advanced Member |
18th Aug, 2015 at 07:33:08pm
On 18th Aug, 2015 larry1275gt said:
of course, but anyone else have a perfect config. of MJ? I doubt it's perfect but I've got the map for my 1330 non turbo engine knocking around somewhere. From memory it's running a Kent 266, the head is ported and flowed on standard MG Metro valve sizes. |
18th Aug, 2015 at 07:44:24pm
There it is, it was borrowed from a chap with a 1380 unit with similar spec to mine. Edited by Midas on 18th Aug, 2015. |
18th Aug, 2015 at 07:47:37pm
It isn't letting me add the attachment for some reason (probably not recognised file format) PM me with your email address and I'll send it across. |
25th Aug, 2015 at 03:02:57pm
thanks Midas |
Page: |
