Home > Wanted > Megajolt V4 molex connector
adam1330
Member #: 238
essex
i'm in need of a megajolt v4 molex connector with wiring...ideally all 16 pins wired up, but if not the bare minimum will do the job.
A computer power cable (atx )can be cut down if you get stuck
mossy2a
Member #: 9751
Derbyshire
I think I've got a few knocking around somewhere. Bare bones though. You will have to crimp the pins. You can have your own colour cable then
Tomm
Member #: 1432
Kent
I got mine from RS. Can not remember the part number though. As Brett said, ATX connectors off of eBay work. Damn sight cheaper as well.
