Home > Wanted > Some mild steel tube with a odd size
Can anyone help with a good supplyer,,
I am looking for some 26.80mm diameter pipe, or I was thinking of getting some 27mm and turning it down to size. So maybe 27mm x 2mm thick wall.
Can anyone shine some light on where to get some?
Thanks simon.
You might have better luck looking for 1 1/16" dia
graemec
Member #: 1424
Carnforth, Lancs
Shame you don't want alloy - it's a standard bike seat post size.
graemec
Member #: 1424
Carnforth, Lancs
Edited by graemec on 3rd Aug, 2015.
whats it for, what material and how long?
Mild steel should do the job,, I only need about 300mm of it,
Might get a steel seatpost in that size if you look about
if it was a short bit, I was gonna say you might get away with stretching some 1" that much on a mandrel.
Thinking I may just turn something up
mossy2a
Member #: 9751
Derbyshire
your just shy off standard Schedule pipe work. 3/4" pipe that i purchase for oil and gas is 26.7mm, next size up is 33.4.
can get whatever thickness you want normally.
would 26.7 be any good to you?
search ansi pipe schedules on google.
Edited by mossy2a on 6th Aug, 2015.
