Page: |
Home > Beginners Tech > Block prep - Arp and main straps? | |||||||
51 Posts Member #: 10894 Advanced Member Lancashire |
2nd Aug, 2015 at 10:00:23am
Been having a bit of a read on here, David vizards book, and listening to some advice around Arp and mainstraps prior to getting my block work done.
2094 Posts Member #: 9894 Post Whore Dorking |
2nd Aug, 2015 at 10:22:29am
Main bolts, standard, rod bolts go ARP. |
2nd Aug, 2015 at 10:33:11am
std mains bolts are fine, unless reving lots. in which case go for studs rather than bolts. I like to use swiftune maincap dowels, really nicly made and cheap!
167 Posts Member #: 11091 Advanced Member |
2nd Aug, 2015 at 11:51:26am
Moss europe do a main cap strap & bolts for £8
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
2nd Aug, 2015 at 12:28:46pm
20" overbore. My word. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
2nd Aug, 2015 at 01:03:17pm
On 2nd Aug, 2015 apbellamy said:
20" overbore. My word. That's why I only got a bag of swarf back! Arhh! |
2nd Aug, 2015 at 01:49:54pm
20" overbore. My word. no replacement for displacement although i do hear the cylinder walls get abit thin |
4304 Posts Member #: 1321 Post Whore Wiltshire |
2nd Aug, 2015 at 05:03:47pm
On 2nd Aug, 2015 Will said:
personally i'd spend the extra couple of ££ to not have to worry about it With the poor quality bolts supplied with many kits a lot of them probably weaken that area. get a strap from force racing if bothering at all. I won't be fitting one until turning over 7.5-8k On 7th Oct, 2010 5haneJ said:
2nd Aug, 2015 at 06:06:49pm
Thanks for the replies guys, in summary
2nd Aug, 2015 at 06:33:53pm
Any idea on your red line? I destroyed an engine at 7000 rpm (very light loads while mapping ) in a very short time. Machining the strap shouldn't cost a lot (free for my last one) so if your redline is anywhere close to that, IMO it's a cheap and sensible precaution.
Edited by PhilR on 2nd Aug, 2015. |
2nd Aug, 2015 at 06:58:13pm
Red line will be 6000rpm, absolute max 6,500 |
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
2nd Aug, 2015 at 07:10:42pm
So you say, but when the red mist descends..... |
2nd Aug, 2015 at 08:36:18pm
Fit a soft hitting rev limter? That stop you over reving it. But after owning a mx5 the redline is best place to shift |
Page: |
