Home > Show Us Yours! > K1100 - Megasquirt
16vmini
Member #: 5037
https://www.youtube.com/watch?v=JZRnna2jAkc
have not found anyone else thats running Megasquirt on one of these yet , but im just starting. :)
yes exhaust falls off at end :)
Man you don't want to get your nuts too close to a spinning flywheel! Gulp
Edited by gr4h4m on 31st Jul, 2015.
16vmini
Member #: 5037
been married 12 years , not needed anymore
Well done, although I agree with Graham about your proximity to the flywheel, but at least it's on an engine stand and not just the garage floor.
You're probably right which is surprising - even the humble MS2 can do fully sequential injection on a normal 8 port engine (as well as the fancy stuff it can do on siamese port engines) if it's built right.
And if you're DIY orientated (as you obviously are) it is very cost effective. Even the MS3, which most people seem to be moving to apart from me, is still cheaper than most of the other aftermarket systems.
16vmini
Member #: 5037
exactly the reasons i use MS ( third one now ) only running batch firing for now.
16vmini
Member #: 5037
got another day at my dads , we filled it with water and ran it up to temp , played around with timing and fuel , lots more tuning to do , but have now brought engine home to be fitted into car
https://www.youtube.com/watch?v=hiaGMipHWUQ
There are a few of these engines out there with megasquirt. You don't hear much from them cos they work. There are also a few on DTA, Emerald, VEMS and then of course the other lot.
Yep, no problems with running squirt on one of these, mine will be, and I was running squirt on my 7 port.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
its missing the turbo..
