Home > General Chat > Oil cooling question!
Ryancarlin1
Member #: 11056
South yorkshire
I've just bought a turbo technics setup, the person who was using it last was running 2 oil systems. So his normal engine one with a oil cooler, the a secondary one with a oil cooler feeding something else, I'm guessing it was just for the turbo, has anyone seen this before?
JT
Member #: 637
Hertfordshire
Not sure if it's necessary using a separate oil system for the turbo.
Most set ups I know of use the engine oil for the turbo. Some don't even use oil coolers!
My build thread..
Second system would surely need a second pump for a start and all seems a bit unnecessary. Depending on the use, many don't even use a cooler these days, particularly with new oils.
Ryancarlin1
Member #: 11056
South yorkshire
It has got a pump mate, it's a full oil system, just unsure on what It was cooling.
PhilR
Member #: 10034
Birmingham
Have you asked the seller?
IMO and experience its not needed for our application in the A series turbo engine a 6 row cooler is more than up to the job for the whole engine and gearbox on the road and a 13 row for track use giving it some beans. the optimum oil temp for power is 100c but most only get to around 85c on average
Ryancarlin1
Member #: 11056
South yorkshire
Can't get in touch with the seller as the guy I bought it off bought the engine all ready turbo'd and didn't no much about it, I'll probs just do away with it
