Page: |
Home > A-Series EFI / Injection > Fitting a Cam sensor | |||||||
1434 Posts Member #: 8466 Post Whore Mansfield |
8th Jul, 2015 at 06:50:39am
Can anybody advice me on how and where I can install a cam sensor on my 7 port 8 injector build. I'm looking for a light weight solution. I assume I can use either use the dizzy drive, fuel pump hole with a modifaction to the cam or fit a sensor to the timing cover?
Edited by alaskanow0 on 8th Jul, 2015. Class C 3rd Place Avon 2011 14.18 @101mph |
539 Posts Member #: 6807 Post Whore York |
8th Jul, 2015 at 07:03:59am
Turn the fuel pump lobe off the cam and cross drill it for a grub screw in the correct position.
3588 Posts Member #: 655 Post Whore Northern Ireland |
8th Jul, 2015 at 08:02:37am
The above would work fine. Or no doubt you could maybe use the lobe itself alone with a hall effect sensor..
8th Jul, 2015 at 08:02:43am
or if your using the fuel pump as a drain...
8th Jul, 2015 at 08:34:24am
Yes, done this a few times now. Made a couple of cam sensors from dizzies.
8th Jul, 2015 at 08:34:39am
if you do drill/tap cam sprocket one thing to watch out for is dont use an alen cap head bolt as ive had trouble with it giving two signals really close together
8th Jul, 2015 at 08:52:42am
I use the dizzy drive with a machined down dizzy body, cut down dizzy shaft with a slotted wheel mounted on it and an opto switch.
8th Jul, 2015 at 12:37:07pm
Great info guys. I'm using a alloy simplex and DSN billet cover (weighs more, but less prone to leaks).
8th Jul, 2015 at 04:43:34pm
If you can get away with an OEM sensor, then it should be more reliable as it's being used in the environment it was designed for,
256 Posts Member #: 11017 Senior Member Shropshire |
26th Jun, 2020 at 10:43:45am
Guys, bringing this back up as I may need a cam sensor on my MPi block. can't use the cam sensor position on the back of the block as the turbo is in the way, so looking at other options.
26th Jun, 2020 at 11:51:14am
In principle, yes.
26th Jun, 2020 at 12:44:32pm
On 26th Jun, 2020 Rod S said:
In principle, yes. Things to be aware of, 1, as per Josh above a caphead screw/bolt might give a double pulse (not all ECUs like that) 2, ideally a hall sensor likes a square (ie, parallel) edge rather than a round cap head screw so a hex head bolt aligned correctly would be better. Also most of them like the "height" of the "tooth" to be at least as high as the "width" of the "tooth". 3, not all stainless materials are truly non-magnetic so check the grade you want to buy against whichever Hall sensor you intend to use. Having said all of that, modern hall sensors will detect pretty much anything, they have to, to preserve OEM warranties...... Cheers Rod. I intend to use hex bolts anyway, merely for the convenience and the double pulse. Would it be worth using another material for the fastenerrsr, Ti is also an option, but bit sure if the sensor would pick that up either? Which A number stainless has the least steel in? |
26th Jun, 2020 at 04:13:27pm
Depends on the vernier duplex but mine have always had stainless screws so I changed one to HT steel. Stainless is not detected by hall sensor.
Edited by Paul S on 26th Jun, 2020. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
26th Jun, 2020 at 04:17:39pm
26th Jun, 2020 at 05:59:18pm
On 26th Jun, 2020 Steve220 said:
Cheers Rod. I intend to use hex bolts anyway, merely for the convenience and the double pulse. Would it be worth using another material for the fastenerrsr, Ti is also an option, but bit sure if the sensor would pick that up either? Which A number stainless has the least steel in? I wouldn't go overboard with titanium, although it is totally non-magnetic, but overkill on price - but just make sure you use a non-magnetic grade of stainless. Despite what most people seem to think - ironically, or naively - lots of grades of stainless are magnetic. Unless it's a nimonic or duplex, ALL (and I do mean all) the other stainless steels are iron based, so a lot are magnetic. Not sure with the two digit "A" numbers, all the stuff I worked with was the ASTM codes (three digits or more) so just google it to sure - if it comes up as ferritic, avoid it, if it comes up as austenitic your safe (and if it's nimonic or duplex you are super-safe but expect space rocket prices....) Schrödinger's cat - so which one am I ??? |
26th Jun, 2020 at 08:30:59pm
I meant as A1, A2, A4 stainless, but i guess there seems to be another way of gauging iron content.
26th Jun, 2020 at 09:40:22pm
Wasted spark is not an issue but batch fuel injection will depend on you setup. A real MPI setup requires sequential (but I don't know if the Haltech can handle the needed sequential injecton timing). |
Page: |
