Page: |
Home > General Chat > Play mini exhaust? RC40? | |||||||
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
26th Jun, 2015 at 11:40:42pm
Chaps,
26th Jun, 2015 at 11:42:57pm
Sorry can't get the play mini link to work... on their website its the 'PM40B'... |
27th Jun, 2015 at 08:17:30am
Its not clear but the play mini system has a larger bore (cant recall exactly). The rc40 one you have linked has the same tailpipe but the system bore is 1.75" and a bit small from what we found in the past for high power use |
27th Jun, 2015 at 08:20:56am
Go for the play mini 2" system nothing comes close fro outright flow and a nice! Sounding note.
27th Jun, 2015 at 09:35:49am
Ok chaps.... Playmini it is then 😛 |
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
27th Jun, 2015 at 10:10:52am
On 27th Jun, 2015 BENROSS said:
Go for the play mini 2" system nothing comes close fro outright flow and a nice! Sounding note. 2" single backbox ......... not the 1.75" Would you say the same for n/a too? On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!! ![]() 1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
27th Jun, 2015 at 11:10:03am
Depends on spec Dave. Rc40 has always been a good performer for smaller power |
27th Jun, 2015 at 11:28:06am
Guys what do I need in the way of hangars...? Does the link pipe connect to the down pipe from the turbo and then to the back box and just hang free? Can't remember what the old one was doing when I took it off.... And the back box, is it just the two hangars connected to the subframe? I see when searching that some guys use stainless steel jubilee clips instead of the rubber rings... |
27th Jun, 2015 at 11:40:02am
Personally, i use the hanger kit with the rubber bobbins. Only need the kit if you are using the earlier rear frame (later post 93 i think cars had the hangers welded to the frame). There are 2 points on the rear frame to mount/ hang it from |
27th Jun, 2015 at 07:34:53pm
dave, yes for the n/a also its an nice sound a deep thundring note like a
![]() 4629 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
27th Jun, 2015 at 08:32:38pm
The requirements for an exhaust system for a NA engine are completely different to those of a Turbocharged engine.
Edited by Turbo Phil on 27th Jun, 2015. |
Page: |
