Home > Technical Chat > megajolts hard cut limiter
or more specifically the signal the megajolt ecu gives out to activate the hard cut module
any one know if this is this just an on / off signal?
ie ON when rpm > limit and OFF when rpm < limit
Apparently cuts every other spark.
Cool I guess that will be just a blind 50% duty cycle i dont think mjlj processes the engine position
Ah. It's not a cut, just reduced current...
"Rather than completely cutting power, the approach taken by the Hard Rev Limiter module reduces current to the coil pack to a level where spark is suppressed, and decreases the chance of mis-firing by allowing the current in the primary windings to ramp down rather than be cut off abruptly."
Taken from here...
http://www.autosportlabs.net/Hard_rev_limiter_1.2.0
yeah thats to stop the coil discharging at a random crank angle,
i think i need to get a module built up and tested on the car
I have one that stopped working. I could whack it in the post for you if you wanted to try bringing it back to life?
That would be brill mate pm incoming
