Home > General Chat > Midlands Rolling Road For Setting Up SUs?
slater
Member #: 1291
Suffolk / Birmingham
Got twin SUs on the moggie that need some attention. Have people got some reccemendations for competent people with the right bits to hand? Close to Birmingham as poss please!
1380rich
Member #: 9766
Warwickshire
Southam mini and metro centre are excellent with carbs. Highly recommend
01926 815681
Avon 2010 class c 3rd
Nick
Member #: 154
Midlands
there's Aldon Automotive in Brierley Hill too
Wouldn't take my car to aldon or high tech personally. Southam as above or steve walford motorsport.
JetBLICK
Member #: 1261
Droitwich
Theres a place in bromsgrove called tts or tps or something on the aston fields industrial estate thats quite good.. Or another vote for southam if ur prepared to go a bit further, definitely worth a trip
TTP Bromsgrove run by a guy I know Malc Fitzpatrick. Malc knows his way round an SU.
Shauna
Member #: 10424
Swansea boyo!
I couldn't recommended Steve or Southam enough, just be aware you might neee to book quite far in advance for Southam as last time I went they said they were getting super busy.
slater
Member #: 1291
Cheers guys
wolfie29177
Member #: 476
The Black Countraaaaay
HiTech in Cradley. The guy is real old school with his knowledge of SU's and A series engines
Masturbation is not a crime its a hobby
steve1275
Member #: 951
Bromsgrove
Malc at TTP is a great guy. He's also 6' 5'' and struggles to get into my MG Midget for the RR so he'd really struggle in a mini. *hehe!*
'Where does the engine go?'
I used to think the same. But considering Shauna's car went in running and driving okay on 8psi, and subsequently it came out broken, i would never take it back. Basically, they didn't understand the heat soak from it being sat, tried blaming a blockage in the carb, tried blowing it out with compressed air, it then ended up puddled in fuel in the inlets and even the plenum had a float bowls worth of fuel in it. Then they were insistant it was the needle valve. That has only been in the carb since everything else had been fitted, so not long. Either way i found the flooding when i stripped it down to get it running again, phoned them up about it after they charged her to screw it up, and he still insisted it was the needle valve and wouldn't accept responsibility for what they had done. Which is why I will never use them again nor will I recommend them again.
Edited by Carlzilla on 14th Jun, 2015.
