Home > Track, Drag & Race > North Weald RWYB 07/06
Usually a good day out. I'm going to try for a decent 13 sec pass. Should be capable after all the changes I've made to the car since the last time. Fingers crossed.
https://www.facebook.com/northwealdmotorspo...828081003966713
Wow. What a busy day. There were 200 cars running up the strip.
Managed a new PB on the first run on just 16psi. 13.75 @ 104.
Previous best was 13.9, but I'd only fluked this once. I was doing regular 14.3's. Since this I've changed the wheels and shad about 40kg out of the car.
Got 5 in total, each getting quicker. I got the boost up to 20psi which lead to the launches falling to bits.
Nailed it on the last run with a 13.28 @ 107mph. Woohoo.
Definitely more to come out of the car.
I'll put some pics and vids up later.
http://youtu.be/tHzlPhFEmxM
JT
Member #: 637
Hertfordshire
That's great!
Do you think you'll brake ino the 12's one day?
My build thread..
I was going two tenths quicker each run. Although the 13.28 was pretty much as good as I could get it.
I reckon with a bit more weight out of it and a proper suspension setup it may get into the lower 13's/high 12's.
Shit. I can't believe I'm talking about trying to get it into the 12's! There's always the next hurdle eh.
Edited by theoneeyedlizard on 7th Jun, 2015.
Mike-998
Member #: 9774
Buckinghamshire
Awesome, well done! Does it feel any different to drive after the modifications?
Totally different. Much more grip. Much more compliant over the bumps.
70 profiles tyres are great.
D4VE
Member #: 10749
lowestoft suffolk
According to your youtube it was a 12.28 @ 107
Nothing gets past Dave lol
excellent job gary.
Whoops mistyped that. Lol
How on earth do you edit stuff on YouTube???
Cheers Robert.
D4VE
Member #: 10749
lowestoft suffolk
Id leave it 😉 lol
Sorted it now.
Hell fire!!
Good work!
ATB would basically get you into the 12's....
Best start saving the pennies then.
There's a ton of weight still to come out of it. The front end is all steel, the doors are completely standard 18+ kgs inc glass. That's before I start with the little bits.
Good video showing what to expect at the July events. If anyone fancies a go?
https://www.facebook.com/tappetmagic/videos/884444908293407/
Edited by theoneeyedlizard on 10th Jun, 2015.
