Home > A-Series EFI / Injection > MPi fuel rail connections
beejay
Member #: 10785
Derby
I have an MPi manifold and fuel rail I'm fitting at the moment. the fuel rail has two flexi connections on it with some sort of push on connection on the end. these fit onto 8mm OD copper fuel line but don't seem to lock in any way. Am I missing a trick here or is there some sort of male fitting required? Never seen an MPi to know what these plug into!
tmsmini
Member #: 7637
Fremont California
You can see the ends in this thread:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=516036http://www.turbominis.co.uk/forums/index.php?p=vt&tid=516036
beejay
Member #: 10785
Derby
Cheers, did manage to find something similar to those in the other thread but wasn't 100% they would fit. Rather than take the risk I ended up chopping the hoses off and putting an AN compression fitting on :)
