Home > General Chat > Ball Joint Tapers
Elfman
Member #: 10737
Swansea
I know its been asked before but does anybody now the exact angle of the taper reamer needed to cut the correct tapers into the arms ?
I need to make custom arms for a space frame Mini but would still like to use the original ball joints as they last a lot longer than Rose Joints.
One helpfull chap has said its a No2 Plumbers Reamer of 6.8 degrees ?
Does anybody now any different
Any help appreciated
Phil
Tupers
Member #: 9441
South Devon
Someone quotes 7 degrees here. http://www.locostbuilders.co.uk/forum/3/vi...d.php?tid=77261
kcchan
Member #: 8853
There is a guy on another forum selling a tapered reamer for this exact job, he quotes it as a "1.5" over a foot tapered reamer"
I thought it was 7 deg too, isn't a more taper 7?? For a reason.
Elfman
Member #: 10737
Swansea
If you can find out the forum its for sale I would be very gratefull,,, I have heard 7 degrees and 1.5" over a foot as the imperial measurment would make sence...Many thanks for youe help
slater
Member #: 1291
Suffolk / Birmingham
Morse is ~3 degrees i think. Certainly much shallower than a ball joint.
http://www.16vminiclub.com/forums/showthread.php?t=36866
1.5" over 1 foot is 7.13 degrees
slater
Member #: 1291
Im doing mine on the lathe, no reamer needed.
Elfman
Member #: 10737
Swansea
Great I was reasonably close... its amost sorted now, many thanks.
One part of many in a long list..
Edited by Elfman on 24th May, 2015.
I had my dad measure mine and its exactly 7 degrees. Fastcarl has just made me some ends for my new wishbones at 7 degrees and theyre spot on
