Home > Wanted > old CAST MANIFOLD for HS4 carb
hi gents i need a old cast manifold the one where its cast for the exhaust and the carb in one, to fit for a n/a engine to fit a HS4 carb and if you have it the old plastic air filter box as well
need this for a friend so he can fit the traditional pea shooter exhaust ............. any one ? chaps
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
If you canīt sort it locally, i have an old manifold. Should it be with servo takeoff or without ?
If i have more toys than you when i die, I WIN
northernminiman
Member #: 11050
Knottingley, West Yorkshire
I've got one mate
Edited by northernminiman on 20th May, 2015.
