Home > General Chat > spluttering off boost
tomostrash
Member #: 10334
Staffordshire
Hi guys please help! My mini turbo has always spluttered off boost but is ok from 2500+ ish rpm,ive possibly checked everything but may have over seen something . I've set co at 3.5,timing is spot on,new fuel regulator and pump.Plugs new with leads And dash pot is full. It doesn't feel like electric but most likely fuel related but I'm stuck. Kind regards
Has it been on the rollers, have you got a Wideband lambda fitted?
as above what tom says, change the coil if you have one. thats a hunch.
