| Home > General Chat > Brake Master Cylinder Sizes | |||||||
6th May, 2015 at 01:32:40pm
Chaps and Chappaties
248 Posts Member #: 7936 Senior Member DK-8450 Hammel. Denmark |
6th May, 2015 at 01:38:47pm
Smaller bore will give higher brake fluid pressure.
If i have more toys than you when i die, I WIN |
6th May, 2015 at 01:39:34pm
I wonder if .50 is too small? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
6th May, 2015 at 01:49:25pm
Have you not changed the calipers though? Master cylinder to caliper needs to stay in a similar ratio as before.
6th May, 2015 at 01:50:44pm
Remember the cylinder/caliper on the other end of the bake pipe will have an effect too I run a supercharger and I don't care the TB is on the wrong side.
6th May, 2015 at 02:18:42pm
Good point, rear calipers are 4 pots and front are 6 pots. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
6th May, 2015 at 02:34:37pm
So if I measure each piston on the calipers and add them together. What should the Ratio be? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
6th May, 2015 at 02:52:55pm
My god just read a calculator table.
6th May, 2015 at 04:20:08pm
Ideally you would measure old calipers and master cyl. For each calculate area by using pi x radius^2 then work out your old ratio as a starting point.
6th May, 2015 at 04:26:24pm
+1 with Tom. When I did the fiesta setup I did check against the standard mini setup because I was worried about the large single piston. I run a supercharger and I don't care the TB is on the wrong side.
6th May, 2015 at 04:33:11pm
Not sure if it'll help you but i use a .625 on the front and a .75 on the back on my wilwood dual bias. Set it up with pretty much all on the front with not to much pedal effort.
