Page: |
Home > 998cc > dizzy | |||||||
239 Posts Member #: 7577 Senior Member belgium |
4th May, 2015 at 08:30:51pm
What type of dizzy can i use for a 998+20cc turbo with 12G295 head??
4th May, 2015 at 09:33:48pm
I'd just spend the extra money and have it mappable on megajolt alot more controllable. I was gonna do Dizzy but quality of parts these days aren't amazing with Dizzy |
2094 Posts Member #: 9894 Post Whore Dorking |
4th May, 2015 at 09:41:04pm
Any reason for wanting to keep a dizzy? |
6745 Posts Member #: 828 Post Whore uranus |
5th May, 2015 at 08:46:32am
pieter ,
5th May, 2015 at 08:59:34pm
i was thinking of building a cheater rod so keep it looking original but having a beast inside... @robert, your plan makes sense, but there is ignition advance curve then... swiftness has these fancy ignition coils that have various ignition curves that can be set, therefore i thought there should be something affordable that does the same as well... or just use the standard dizzy from the 1275 metty block? but the block i have is a A block not A+... |
Page: |
