Page: |
Home > General Chat > Bolt size | |||||||
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
29th Apr, 2015 at 08:30:40pm
Hi, does anyone know the bolt size for the 4 bolts that bolt the flange of a T3 to the manifold? Just realised the bastards didn't send em back after reconditioning the T3... |
29th Apr, 2015 at 08:32:38pm
m8 On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it ![]() |
29th Apr, 2015 at 08:38:38pm
What about the thread...? |
29th Apr, 2015 at 09:08:54pm
Pitch I mean, as in standard 1.25? |
29th Apr, 2015 at 10:16:18pm
just normal m8 iirc
Yes i moved to the darkside |
30th Apr, 2015 at 08:41:57am
Ok thanks.. |
3591 Posts Member #: 655 Post Whore Northern Ireland |
30th Apr, 2015 at 09:46:07am
On 29th Apr, 2015 evad1980 said:
Hi, does anyone know the bolt size for the 4 bolts that bolt the flange of a T3 to the manifold? Just realised the bastards didn't send em back after reconditioning the T3... The 4 bolts that go through the T3 flange onto the exhaust manifold on a metro turbo are standard M10x1.5 Although I'm sure I recall them being studs coming out of the manifold though, same thread either way Edited by stevieturbo on 30th Apr, 2015. 9.85 @ 145mph
30th Apr, 2015 at 09:52:59am
T3 is M10 and they are studs in the manifold with nuts and some kind of locking plate/shim under the nuts on the turbo side. If something is worth doing, it's worth doing half of. |
30th Apr, 2015 at 06:33:34pm
Yes discovered that today thanks. Took the manifold out with me today in the hunt for bolts... |
Page: |
