Page: |
Home > 998cc > Bike carbs | |||||||
32 Posts Member #: 11050 Member Knottingley, West Yorkshire |
28th Apr, 2015 at 01:21:54pm
I know it's not a turbo but has anyone used bike carbs in the past and can shed any light on specific carbs to us and also fitment |
1750 Posts Member #: 10190 Post Whore belgium |
28th Apr, 2015 at 03:01:33pm
I had suzuki gsx 1000 carbs on my 1275... after lots of rejetting and finding the right links i blown the engine... you can do anything if you set your mind to it...
28th Apr, 2015 at 03:09:24pm
Not good mate |
4890 Posts Member #: 1775 Post Whore Chester |
28th Apr, 2015 at 04:26:42pm
I used a bike carb for years on my supercharged 998. The rolling road blocked an air hole, new jets and made a custom needle and it worked great! I run a supercharger and I don't care the TB is on the wrong side.
28th Apr, 2015 at 06:30:40pm
Cheers for that |
28th Apr, 2015 at 08:47:38pm
The issue that you have is finding big enough to flow . As the bikes use one per cylinder. I think the r1 are about 41mm I used a 38mm but I can't remember what the bike was, a big 900cc thing.
28th Apr, 2015 at 09:56:00pm
a yeah it was a bad second... but i trached that vw golf at the lights so... jipicajee to that
On 28th Apr, 2015 northernminiman said:
Not good mate you can do anything if you set your mind to it...
29th Apr, 2015 at 06:55:39am
As above size is the issue. What is Robert using on Medusa?
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
29th Apr, 2015 at 07:33:50am
I'd just stick an HIF on. Job done. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
29th Apr, 2015 at 08:33:33am
A set of harley carbs would do to... yet do not know what the profit would be and like apbellamy says... maybe a flown hif is stil the best thing. you can do anything if you set your mind to it...
169 Posts Member #: 9128 Advanced Member |
29th Apr, 2015 at 09:18:01pm
I've always thought a big harley performance carb, you can get them upto about 51mm. |
30th Apr, 2015 at 04:43:56am
But they have a long travel. Even the weber once. you can do anything if you set your mind to it...
6745 Posts Member #: 828 Post Whore uranus |
30th Apr, 2015 at 05:46:04am
i;m using 12 gsx600 38mm ones , with a 660 cc cylinder size , but they are just throttle bodies and the fuel goes through a lpg mixer.
30th Apr, 2015 at 11:56:50am
The thunder jet was the one I had
46 Posts Member #: 11122 Member Scottish Borders. |
3rd May, 2015 at 05:15:58pm
hi guys, im interested in the bike carb route for my own 998 turbo build. would the likes of the 44mm mikuni be suitable for a blow through application under boost? is it a sealed unit? |
3rd May, 2015 at 06:14:34pm
If you want to use a carb on a turbo, the HIF is the best and simplest choice.
2094 Posts Member #: 9894 Post Whore Dorking |
3rd May, 2015 at 06:29:59pm
Don't get the whole appeal of this bike carb craze. It does seem to be quite a 'thing' at the moment.
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
4th May, 2015 at 06:58:23am
It is not new. Back in the sixties when I were a lad, we fitted twin Amals to Minis and even further back some tuners used four Amals on other( four port) engines.
4th May, 2015 at 07:46:01am
The main advantage is that they are not all worn out.
On 3rd May, 2015 jonny f said:
Don't get the whole appeal of this bike carb craze. It does seem to be quite a 'thing' at the moment. I run a supercharger and I don't care the TB is on the wrong side.
65 Posts Member #: 8079 Advanced Member York |
4th May, 2015 at 06:37:55pm
I used to use a pair off a cbr 1000 (half a bank) on my 1330 n/a engine. Dave Bogg set it up on their rollers and it ran well. Took them off when I went to the current spec (296/ full race head) as they ran out of legs so swapped to a 45 weber. We considered a pair of vtr 1000 carbs, as they are 52mm iirc. No turbo experience though. |
Page: |
