Page: |
Home > Non-Mini Projects > Can I fix this with JB weld? | |||||||
293 Posts Member #: 10010 Senior Member Northants |
16th Apr, 2015 at 09:23:25pm
As above, we had a little problem with the engine on our dyno at University, do you reckon we could save it with a bit of JB weld or similar?
4890 Posts Member #: 1775 Post Whore Chester |
16th Apr, 2015 at 09:38:30pm
JB WELD easy fix :) I run a supercharger and I don't care the TB is on the wrong side.
16th Apr, 2015 at 09:46:23pm
Rings look a bit iffy. Best change them to be on the safe side. Edited by PhilR on 16th Apr, 2015. |
16th Apr, 2015 at 10:37:20pm
What it more of less looked like prior to the 'incident'
17th Apr, 2015 at 07:06:11am
What happened there then?
6745 Posts Member #: 828 Post Whore uranus |
17th Apr, 2015 at 12:49:49pm
thats what i was wondering wil ,
17th Apr, 2015 at 08:30:10pm
What happened? Good question.
Edited by jakejakejake1 on 17th Apr, 2015. |
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
27th Apr, 2015 at 11:25:24am
sloppy piston with drastically undersize skirt? when its cold itmay have been wee enough to dig in and flip over? turbo 16v k-series 11.9@118.9 :)
855 Posts Member #: 951 Post Whore Bromsgrove |
27th Apr, 2015 at 06:02:10pm
Possibly one or more valves stuck or lost contact with the cam. once even marginally bent they would stay open,hit the piston very hard and possibly flip it, The rest is consequential damage. Check the contact between open valve and piston from the drawings. what state are the cam lobes in? 'Where does the engine go?' |
Page: |
