Page: |
Home > Help Needed / General Tech Chat > Centre Main Strap Issues | |||||||
14th Apr, 2015 at 09:29:35am
Morning Guys
![]() 190 Posts Member #: 8935 Advanced Member netherlands |
14th Apr, 2015 at 09:50:46am
looks like they took off to much of centre main cap??!! Edited by clubbie70 on 14th Apr, 2015. |
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
14th Apr, 2015 at 10:15:37am
Nothing wrong with what you have. It's just that in cutting down the cap to the height of the bolt shoulder removes the thrust washer locating slot.
Edited by Paul S on 14th Apr, 2015. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
![]() 696 Posts Member #: 10034 Post Whore Birmingham |
14th Apr, 2015 at 10:25:23am
Nope, that's right for a small-bore cap. You don't have to take so much off with a 1275 cap, so the original slot doesn't get machined away.
Edited by PhilR on 14th Apr, 2015. |
14th Apr, 2015 at 10:48:29am
On 14th Apr, 2015 Paul S said:
Nothing wrong with what you have. It's just that in cutting down the cap to the height of the bolt shoulder removes the thrust washer locating slot. Usually we get around that problem by using a wide strap and cutting a new slot in the cap. ![]() I recall that someone once said that they had problems with the sharp edge on the cap cutting into the thrust washer tab. I run a supercharger and I don't care the TB is on the wrong side.
14th Apr, 2015 at 11:42:26am
This seems the standard way that 998 centre main straps are machined. If you have a light clutch you'll probably get away with it.
14th Apr, 2015 at 12:39:07pm
Wil the think his issue is that the strap he has is too thin so the thrusts are flush when it's fitted. Carl did the same as yours and added some dowls into the strap to locate the tang on the thrust I run a supercharger and I don't care the TB is on the wrong side.
14th Apr, 2015 at 09:01:20pm
Ill upload another photo and you guys can see
14th Apr, 2015 at 09:43:59pm
15th Apr, 2015 at 05:54:37am
Like I said in your build thread. file a slot in the block and put the thrusts in the other way up. Quicker than making a new strap. |
15th Apr, 2015 at 09:04:29pm
Thanks Slater
17th Apr, 2015 at 07:11:01am
File a slot in the block. Listen to what people suggest! On 13th Jul, 2012 Ben H said:
17th Apr, 2015 at 07:51:11am
I'm taking Paul's Option.
On 17th Apr, 2015 Vegard said:
File a slot in the block. Listen to what people suggest! |
17th Apr, 2015 at 08:42:18am
You could file it at 12 degrees if you want to....
17th Apr, 2015 at 08:48:53am
Other option would be to drill and screw the thrusts to the block & cap. If something is worth doing, it's worth doing half of. |
17th Apr, 2015 at 11:15:26am
How would a slot in a strap weaken it?
You could file it at 12 degrees if you want to.... You prefer weakening the strap ![]() |
17th Apr, 2015 at 11:59:29am
17th Apr, 2015 at 12:00:00pm
Not if they are counter sunk enough. If something is worth doing, it's worth doing half of. |
17th Apr, 2015 at 02:32:21pm
That looks a good idea john no more spun bearings but how do you drill and tap them? |
17th Apr, 2015 at 02:49:42pm
I got Carl @ Force Racing to do mine. But I see no reason why you couldn't do it yourself.
17th Apr, 2015 at 03:20:12pm
Thanks john I'll take a look into it giving me some food for thought |
Page: |
