Page: |
Home > Technical Chat > give me some head... advise. | |||||||
1750 Posts Member #: 10190 Post Whore belgium |
12th Apr, 2015 at 08:00:56pm
Hy. Was looking on what head to use for the turbo. Now i have a very good head but mounted that one to the 998... so only one's left is a standard head without valves. A longman with piiting 2 other longmans who probably be skimmed to much ( and are somewhat rusty ) and this one. A metro head. I have no burets at hand right now but roughly mesured it. Do you thinck it will be able to take some cc's if needed to make compression right? Will only run low psi
4625 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
12th Apr, 2015 at 08:13:03pm
The chambers look completely standard so there should be plenty of scope to increase the volume, unless it's been heavily skimmed.
12th Apr, 2015 at 09:22:40pm
69.11 mm... thats about 2.72 inch you can do anything if you set your mind to it...
12th Apr, 2015 at 10:04:05pm
So yhat is 0.03 inch skimmed you can do anything if you set your mind to it...
12th Apr, 2015 at 10:11:51pm
No problems there then. Plenty to work with.
Page: |
