Page: |
Home > Technical Chat > How much radial clearance is really needed around a valve (piston pockets) | |||||||
7th Apr, 2015 at 01:34:00am
As we know, the K-valves are 23.0 and 26.5mm.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
7th Apr, 2015 at 09:43:52am
It all depends on how well you measure/ mark the pistons to begin with. Me personally, with the way I built my engine, I simply copied the bmw pistons but increased the diameter by 1mm just for the sake of a little miss alignment. All pistons are the same. You can find some pics in my build threads. The cuts are tiny in comparison to the norm! On 26th Oct, 2004 TurboDave16v said:
7th Apr, 2015 at 10:33:51am
So, do you know what diameter the cut-outs in the beemer pistons are? You told me you increased the dia by 1mm lol, but I don't have any beemer pistons as a reference On 17th Nov, 2014 Tom Fenton said:
3588 Posts Member #: 655 Post Whore Northern Ireland |
7th Apr, 2015 at 12:21:46pm
I'd imagine piston rock and movement is a big factor.
7th Apr, 2015 at 01:28:39pm
Stevie
7th Apr, 2015 at 01:33:39pm
And I found this link too...
8th Apr, 2015 at 07:39:30am
Emery disc is a gentler option for valve pockets. The only snag is that when you need to replace the emery disc it might take some time... I used a notched valve to cut pockets to Rover V8 pistons. |
Page: |
