Page: |
Home > Help Needed / General Tech Chat > No or very little oil pressure | |||||||
5th Apr, 2015 at 08:14:58am
Got a bit of an issue with the mini as in i've got very little oil pressure.
Edited by Rob Gavin on 5th Apr, 2015. |
5th Apr, 2015 at 08:38:33am
Hi rob, loose oil pump or gasket not seated correctley, the next one and my monies On this. . . . . . . . The O ring between the gearbox and block will be There as you are sure you have fitted this.
5th Apr, 2015 at 09:54:02am
Cheers Steve. I've had similar thoughts. Going to pull it tonight to confirm |
7th Apr, 2015 at 09:42:01am
well I am a fool. Complete schoolboy error I may have inadvertently left a sheet of blue roll in the engine during assembly and the gearbox has now turned into, as Oli has described it so eloquently, a saniflo.
7th Apr, 2015 at 09:49:08am
Whoopsie On 26th Oct, 2004 TurboDave16v said:
7th Apr, 2015 at 09:53:49am
That bloody blue roll, its a fucking menace, years ago a good mate and I spent 3 days on a 205 GTI rally car with a newly built engine that we couldn't get to fire up. You name it we changed it, wiring looms, ECU's, injectors, fuel system, air flow meters, blah blah blah.
7th Apr, 2015 at 11:11:34am
Glad I'm not the only one then Tom! |
974 Posts Member #: 3228 Post Whore North of the Netherlands |
7th Apr, 2015 at 12:32:44pm
You're deffinately not alone Rob.
Dazed and Confused.... |
7th Apr, 2015 at 12:53:46pm
Don't you hate engine building! I run a supercharger and I don't care the TB is on the wrong side.
7th Apr, 2015 at 04:05:40pm
At the moment, yes! |
![]() 65 Posts Member #: 613 Class D Massive Regular glasgow |
7th Apr, 2015 at 07:11:13pm
Worry not m8, we've all done something similar. At least you had the nads to own up. |
7th Apr, 2015 at 07:45:04pm
No choice! |
4306 Posts Member #: 1321 Post Whore Wiltshire |
7th Apr, 2015 at 07:56:35pm
Bugger, at least its saved a load of head scratching, even if it has caused a load of work! On 7th Oct, 2010 5haneJ said:
7th Apr, 2015 at 08:22:36pm
My we bro did this with his spitfire, he had removed the inlet for whatever reason and stuffed roll into the inlet ports to keep the crap out. few days later duely bolted the inlet back on and fired it up, took ages to start, and when it did there was ,what i can only describe as, confetti out the exhaust, all black and burnt. gave us a hell of a fright! turbo 16v k-series 11.9@118.9 :)
7th Apr, 2015 at 08:35:00pm
Clearly i'm not the only dafty then! |
2nd Jul, 2015 at 08:12:20am
well the car is on the road again but oil pressure is still a major issue.
Edited by Rob Gavin on 2nd Jul, 2015. |
2nd Jul, 2015 at 08:32:44am
Engine out. Build oil pressure on starter, time it and make a note of the readings.
2nd Jul, 2015 at 08:33:28am
And check the obvious while the box is off like blue-roll etc lol If something is worth doing, it's worth doing half of. |
2nd Jul, 2015 at 08:35:16am
Maybe check functionability of pressure relieve valve before pulling engine? Dazed and Confused.... |
2nd Jul, 2015 at 08:47:24am
the pressure release valve has been checked a few times now; I've not got one of the adjustable ones on it to try that. |
2nd Jul, 2015 at 08:48:02am
good idea john
On 2nd Jul, 2015 John said:
Engine out. Build oil pressure on starter, time it and make a note of the readings. Then take the box off remove the oil jets and grub screw the holes. Box back on and repeat the test. Do it with dry gaskets then you can reuse them if you have to pull it apart for further investigation. |
2nd Jul, 2015 at 09:36:37am
Could the gauge be faulty/reading wrong? My build thread..
2nd Jul, 2015 at 09:38:20am
I checked with another gauge and it was pretty much the same; also oil light is coming on consistent with the pressure drop
On 2nd Jul, 2015 JT said:
Could the gauge be faulty/reading wrong? |
2nd Jul, 2015 at 10:12:11am
Certainly if its coming to bits I would plastigauge the mains and big ends to verify the running clearance are correct. If they are large then you will never get good oil pressure no matter what you do. Especially since the crank came from those rat bastards.
2nd Jul, 2015 at 02:07:47pm
that was my thoughts Tom. I've always assumed it was just a Rover old stock item and discounted it as an issue before but it is one of the few things that has remained consistent in the engine builds
On 2nd Jul, 2015 Tom Fenton said:
Certainly if its coming to bits I would plastigauge the mains and big ends to verify the running clearance are correct. If they are large then you will never get good oil pressure no matter what you do. Especially since the crank came from those rat bastards. |
Page: |
