Home > Beginners Tech > engine stabilizer on a Twinky
Streetscreamer
Member #: 10125
Zoetermeer, The Netherlands
I have searched many pictures, but could not find:
I wonder how to attach an extra engine stabilizer to an A series engine with K1100 head.
You know: these stabilizers normally connect to the three bolts of the thermostat housing on the original A series engine. Or they suddenly aren;t an issue anymore, hardly can't believe..*smiley*.
Anybody who has a nice suggestion?
thanks!
Bracket from Water pump to bulkhead.
Edit: not sure if that will work without some monster bracket to clear the belt, I need to go and play in the garage.
Edited by minimole23 on 2nd Apr, 2015.
Streetscreamer
Member #: 10125
within 4 minutes the 1st answer.. screamin' fast !! thanks. But in all cases: what invention to get along the toothed belt?
slater
Member #: 1291
Suffolk / Birmingham
I don't know of anything off the shelf but easy to make somthing that does the same job
smiffy_no46
Member #: 8079
York
I run 3 rose jointed links from the gearbox to subframe plus a rose jointed link in the std place above the clutch. All will be out of the way of any head/belts and it does not move at all. On the road though, the minispares extra two gearbox mounts will prob be better, as they have rubber in. IMO all the ones from the stat side on std heads look shit and get in the way so never ran them anyway.
caleb
Member #: 11114
Hi
Check out how Matt does it down under.
http://www.ausmini.com/forums/viewtopic.php?f=5&t=75896
modified standard engine steady, the bend clears the timing belt.
Cheers, Caleb
Edited by caleb on 17th Apr, 2015.
