Home > Technical Chat > Who makes the best Centre Main Strap?
Chalkie
Member #: 9764
Northamptonshire.
Afternoon guys
got my engine heading off the to machine shop in 2 weeks time. Now as title says
Who does best Centre main strap?
and are the bolts up to scratch these days?
Thanks Steve
Carl made mine and machined the centre cap plus supplied some high quality bolts
Chalkie
Member #: 9764
Northamptonshire.
Ill drop Carl a PM then
did he surply for all the straps? rather drop some decent bolts in across the board
No I used a plus bolts on the other mains
If your heading to the machine shop. Get yourself the cast 4 bolt main cap and get it lined bored/honed. *wink*
Chalkie
Member #: 9764
Northamptonshire.
Don't do them for the 998 engine :(
what spec is your engine? does it actually need it?
Chalkie
Member #: 9764
Northamptonshire.
998 A plus
276 cam
202 head ported
1.3.1 rockers
lighted flywheels
Balanced roating assmessbly
i was adding one to make sure
Not sure about the 998 but there is a question over ids need on low reving 1275. Having said that, it wax the first mod i did!
Chalkie
Member #: 9764
Northamptonshire.
I know 998 is more free reving then a 1275 so reason i was gonna do it
slater
Member #: 1291
Suffolk / Birmingham
Mini Spares one I fitted last was fine. Correct bolts supplied with it. Wasn't worth making one for cost. One thing I did do was surface grind the bottom just to ensure it was flat. They are not machined there normally.
Just be aware that you can't use a 1275 main strap on a 998 without slotting it for the thrust bearing tabs.
I made my own, I see if I can find a photo.
EDIT: Photo:
Edited by Paul S on 26th Mar, 2015.
For your run of the mill turbo engine I'm now in the don't bother camp. I don't think it's needed unless you are constantly whizzing mega rpm.
Once you get the internals balanced and lightened they spin up quick. I was easily hitting 7.5k in mine without realising.
Chalkie
Member #: 9764
Northamptonshire.
This engine wont be turbo'd maybe supercharged in the future but no turbo
all internals being balanced and lightened
Paul is there much point in a 1275 one?
PhilR
Member #: 10034
Birmingham
Also note the 1275 bolt spacing is different.
Chalkie
Member #: 9764
Northamptonshire.
Thanks I'll Bare that in mind I've Messaged Carl waiting on a reply
Minispares of swiftune was too I was looking at anyways
Swiftune do a 998 version and it's in stock.
valant1
Member #: 1223
Elmer racing can supply a good one for 998
Chalkie
Member #: 9764
Northamptonshire.
Props gonna order one from swiftune as ordering few other bits off em then
Chalkie
Member #: 9764
Northamptonshire.
Any difference between swiftune one and minispares expect for double the price for swift
