Home > General Chat > Turbo diesel engine slight ....issues.
smokestack-lightning.
Member #: 10557
Not a strictly mini thing here but this is one of the most complete failures ive seen on an old style land rover engine.
19J Turbo diesel (t25?) loud rattling and loss of compression on no2 cylinder...... as was towed in to us.
Looks like the pre-combustion chamber has come loose been smashed in half by a piston stroke and the half that has fallen in the cylinder has then broken the piston apart, bare conrod and pin have then had fun with the cylinder........
Double-Blind experiment, N:
An experiment in which the Chief Researcher believes he is
Fooling both the subject and the lab assistant. Often accompanied by
a belief in the Tooth Fairy.
Just needs a bit of JB weld.
That must have made a slight tapping noise
D4VE
Member #: 10749
lowestoft suffolk
That is a rather large failure
Nothing gets past Dave lol
Bang!
Proper job!
Will
Member #: 11091
bit of "steel seal" through the header tank should sort that out *hehe!*
